Bike Finder · Bulls
Bulls Copperhead EVO
Bulls
Copperhead EVO 2022
DiscontinuedFull Power · Cross-CountryLegacy · 1/10iFreshness 1/10
Full-power alloy hardtail with a big 750Wh battery for long trail days
Travel F/R
120mm / —
Wheels
29F / 29R
Frame
Aluminium
Weight
Price
£0
View the Bulls Copperhead EVO on Bulls’s site
Bulls Copperhead EVO 2022
EMTB Forums verdict
The 2022 Bulls Copperhead EVO was the German brand's sporty aluminium e-hardtail, sold in three numbered trims (EVO 1, 2 and 3) across 29in and 27.5in frames with Diamant, Trapez and Wave shapes. The headline '750' versions adopted Bosch's then-new Performance Line CX Smart System with a 750 Wh PowerTube and Kiox 300 display, paired with a 120 mm fork, while cheaper base builds ran the older Performance Line CX with a Purion LCD and a 400 Wh pack.
Trim value steps up clearly. The EVO 1 750 (3,799 euros) keeps things simple with a Shimano Deore 10-speed, a coil-feeling SR Suntour XCM fork and mechanical Tektro brakes. The EVO 2 750 (3,999 euros) gains an air-sprung XCR fork, hydraulic brakes and an 11-speed Deore. The flagship EVO 3 750 (4,299 euros) is the trail-leaning pick with a BULLS Lytro 34 air fork, a 12-speed Deore drivetrain, a larger 203 mm front rotor and grippy 2.6in Schwalbe Nobby Nic tyres.
Geometry is touring-friendly rather than aggressive. The EVO 3 sits at a 66 degree head angle, 74 degree seat angle and 455 mm chainstays, with reach growing from 438 mm to 486 mm across four sizes; the lower EVO 1 and EVO 2 builds run a steeper 67 degree head angle. Bulls' Clean Cockpit System and MonkeyLink interfaces make it easy to add lights and accessories.
The Copperhead EVO is discontinued in this 2022 form. Bulls carried the Copperhead EVO name forward into later model years (2023, 2025 and 2026), and the line has since been reorganised, with the full-suspension Copperhead EVO AM covering the trail end of the range.
Geometry read
Size
Setting
Descending
48
A solid all-round descender (67° head angle, 120mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
66
Short 455mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
61
Rear-long with a planted front in L (FC:RC 1.61) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
72
Bosch Performance Line CX Gen 4 and a steep 73° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Full Power · Cross-Country bikes (from 130 bikes in the database)
Battery750 Wh63 Wh above average
Motor torque85 Nmabout average torque
💬 Forum discussion
Whyte Karve Evo
365 replies · 25.2k views · last reply 2 days ago
Join the discussion →
“I’m getting one in asap. It’s one of the more interesting Avinox bikes I’ve seen so far.”
— Rob Rides EMTB · ♥ 23 · most-liked post
Bike geometry diagram
Flip-chip position
geometry changes with the chip
SMLXLXXL
Reach438 mm449 mm472 mm486 mm478 mm
Stack638 mm647 mm657 mm693 mm699 mm
Seattube440 mm480 mm540 mm600 mm600 mm
Chainstay455 mm455 mm455 mm455 mm455 mm
Headtube Angle66°66°66°66°67°
Seattube Angle (eff)74°74°74°74°73°
Wheelbase1194 mm1209 mm1236 mm1258 mm1242 mm
Headtube120 mm130 mm140 mm180 mm180 mm
Front Centre739 mm*754 mm*781 mm*803 mm*787 mm*
FC:RC1.621.661.721.761.73
Trims · 5
EVO 1
£0
EVO 1 750
€3,799
EVO 2
€3,299
EVO 2 750
€3,999
EVO 3 750
€4,299
MotorBosch Performance Line CX Gen 4 · 85 Nm · all trims
BatteryBosch PowerTube 750 · 750 Wh · all trims
Travel F/R120/? mm · all trims
FrameAluminium · all trims
ForkSR SUNTOUR XCM DS RL, 100 mmSR Suntour XCM 32 DS Boost LO, 120 mm travelSR SUNTOUR XCR 32 Boost LOR Air CTS, 120 mmSR Suntour XCR 32 Boost LOR Air CTS, 120 mm travelBULLS Lytro 34 Air Boost RLR DS, 120 mm travel
ShockN/A (hardtail)N/A (hardtail)N/A (hardtail)
HeadsetFSA no.57 B-1FSA No.57SCFSA No.57SCFSA No.57SCFSA No.55R
StemMTB-S, CCS Slot Mount readyMTB-S, CCS Slot Mount readyMTB-SL, CCS Slot Mount readyMTB-SL, CCS Slot Mount readyMTBi, CCS Slot Mount ready
HandlebarSTYX MTB alloySTYX MTB alloyBULLS MTB alloyBULLS MTB alloyBULLS MTB alloy
GripsSTYXSTYXBULLSBULLSBULLS
SaddleBULLS Sportive ErgoBULLS Sportive ErgoBULLS Sportive ErgoBULLS Sportive ErgoSelle Royal Vivo Ergo
SeatpostSTYX AluminiumSTYX AluminiumBULLS AluminiumBULLS AluminiumBULLS Aluminium
Brakeshydraulic disc brake, TEKTRO MD-M280 leversTektro MD-M280 mechanical disc brakes, 180 mm front / 180 mm rear (6-Bolt)hydraulic disc brake, TEKTRO HD-M390 leversTektro HD-M390 hydraulic disc brakes, 180 mm front / 180 mm rear (Center Lock)Tektro HD-M530 hydraulic disc brakes, 203 mm front / 180 mm rear (Center Lock)
Rear derailleurSHIMANO Deore RD-M5120-SGS Shadow PlusShimano Deore RD-M5120-SGS Shadow PlusSHIMANO Deore RD-M5120-SGS Shadow PlusShimano Deore RD-M5120-SGS Shadow PlusShimano Deore RD-M6100-SGS Shadow Plus
CrankFSA 165mm · all trims
ShiftersSHIMANO Deore SL-M4100-RShimano Deore SL-M4100-RSHIMANO Deore SL-M5100-RShimano Deore SL-M5100-RShimano Deore XT SL-M6100-R
CassetteSHIMANO Deore CS-M4100-10 11-46TShimano Deore CS-M4100-10 11-46TSHIMANO Deore CS-M5100-11 11-51TShimano Deore CS-M5100-11 11-51TShimano Deore CS-M6100-12 10-51T
ChainKMC E10SKMC E10SKMC E11SKMC E11SShimano CN-M6100
DrivetrainSHIMANO Deore RD-M5120-SGS Shadow Plus; FSA 165mm; SHIMANO Deore SL-M4100-R; SHIMANO Deore CS-M4100-10 11-46T; KMC E10SShimano Deore RD-M5120-SGS Shadow Plus; FSA 165mm; Shimano Deore SL-M4100-R; Shimano Deore CS-M4100-10 11-46T; KMC E10SSHIMANO Deore RD-M5120-SGS Shadow Plus; FSA 165mm; SHIMANO Deore SL-M5100-R; SHIMANO Deore CS-M5100-11 11-51T; KMC E11SShimano Deore RD-M5120-SGS Shadow Plus; FSA 165mm; Shimano Deore SL-M5100-R; Shimano Deore CS-M5100-11 11-51T; KMC E11SShimano Deore RD-M6100-SGS Shadow Plus; FSA 165mm; Shimano Deore XT SL-M6100-R; Shimano Deore CS-M6100-12 10-51T; Shimano CN-M6100
WheelsSTYX DDM-2STYX DDM-2 rims; BULLS QR rear hubRYDE Disc 30Ryde Disc 30 rims; Formula CL-2241QR Boost rear hubRyde Disc 30 rims; Shimano HB-MT400-B front / FH-MT410-B rear hubs
TyresSUPERO Edge, 29 x 2,25 (57-622)Supero Edge 29 x 2.25VeeTire Crown Gem, 29 x 2,30 (58-622)Veetire Crown Gem 29 x 2.30Schwalbe Nobby Nic Performance 29 x 2.60
Price£0€3,799€3,299€3,999€4,299
Rides similarly
Spot a mistake?
