Steeper 67.5° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
Aminga EVA TR 1 27.5 2024
Short 445mm rear and a lighter build — easy to pop, manual and throw around.
Not enough geometry on record to judge size balance.
A workmanlike climber — expect to put in more rider effort on the steep stuff. 600W of peak power and 85Nm of torque — a strong full-power motor.
Easy to throw around; happiest when you're active on the bike.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Full Power · Cross-Country bikes (from 104 bikes in the database)
| 41cm (S) | 44cm (M) | |
| Reach | 420 mm | 440 mm |
| Stack | 610 mm | 610 mm |
| Seattube | 410 mm | 440 mm |
| Chainstay | 445.7 mm | 445.7 mm |
| Headtube Angle | 67.5° | 67.5° |
| Seattube Angle (eff) | 74° | 74° |
| BB Drop | 25 mm | 25 mm |
| Standover | 770 mm | 790 mm |
Rides similarly
Spot a mistake?
