A solid all-round descender (66° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
EVO CX AM 2026
Full-power alloy trail all-rounder with 800Wh for genuinely long days
The BULLS EVO CX AM is a value-focused aluminium trail e-MTB built on a Mono-Link swingarm with 140mm of travel front and rear. Both builds run Bosch's Performance Line CX Gen 5 (Smart System) motor, delivered here in a 100Nm / 600W tune, paired with a Bosch Purion 200 display and a 10-speed Shimano CUES LinkGlide drivetrain (RD-U6000 mech, CS-LG300 11-48T cassette). It is a deliberately affordable, do-it-all package rather than a high-end race bike.
The two trims are more different than their names suggest. The AM 2 (EUR 3,999) is the flagship: 29in wheels, an 800Wh Bosch PowerTube, a RockShox 35 Gold RL air fork and a 100mm RUMBLE Escalator dropper, with a claimed weight of 26.8kg. The AM 1 (EUR 3,499) steps down to 27.5in wheels, a smaller 540Wh PowerTube, a Lytro 34 Air fork and a 75mm dropper, at a claimed 26.4kg. Both share the SR Suntour Edge X-2CR shock, Schwalbe Smart Sam tyres, BULLS DDM-30 rims, Shimano BR-MT200-class hydraulic brakes on 180mm rotors and the RUMBLE Altimate cockpit.
Geometry, published by BULLS for the 29in AM 2, is middle-of-the-road trail: a 66-degree head angle and 76-degree effective seat angle right across the range, 445mm chainstays at every size, and reach growing from 438mm on the S to 494mm on the XL. This is a sensible, price-led family aimed at trail riding and off-road touring rather than aggressive enduro use.
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Rear-long with a planted front in L (FC:RC 1.80) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Bosch Performance Line CX Gen 5 and a steep 76° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 120Nm of torque — among the most powerful e-bike motors made.
Strong up and composed down — a do-it-all, not a specialist.
How it stacks up vs other Full Power · Trail bikes (from 271 bikes in the database)
| S | M | L | XL | |
| Reach | 438 mm | 450 mm | 472 mm | 494 mm |
| Stack | 628 mm | 640 mm | 654 mm | 667 mm |
| Seattube | 400 mm | 430 mm | 470 mm | 510 mm |
| Chainstay | 445 mm | 445 mm | 445 mm | 445 mm |
| Headtube Angle | 66° | 66° | 66° | 66° |
| Seattube Angle (eff) | 76° | 76° | 76° | 76° |
| Wheelbase | 1204 mm | 1220 mm | 1245 mm | 1271 mm |
| Headtube | 110 mm | 120 mm | 130 mm | 140 mm |
| BB Height | 344 mm | 340 mm | 336 mm | 332 mm |
| Front Centre | 759 mm* | 775 mm* | 800 mm* | 826 mm* |
| FC:RC | 1.71 | 1.74 | 1.80 | 1.86 |
Trims · 2
AM 1 €3,499 | AM 2 €3,999 | |
| Motor | Bosch Performance Line CX Gen 5 · 100 Nm · all trims | |
| Battery | Bosch PowerTube 800 · 800 Wh · all trims | |
| Travel F/R | 140/140 mm · all trims | |
| Frame | Aluminium · all trims | |
| Fork | Lytro 34 Air Boost 2CR DS 15AH2-110, 140 mm | RockShox 35 Gold RL, 1.8 Steerer, 140 mm, air |
| Shock | SR SUNTOUR EDGE X-2CR, 140 mm · all trims | |
| Headset | ACROS AZX-279, ZS56/28.6/ZS66/40 | ACROS AZX-274, ZS56/28.6/ZS66/46 |
| Stem | RUMBLE Altimate · all trims | |
| Handlebar | RUMBLE Altimate 35 Riser · all trims | |
| Saddle | BULLS MTB-Sport · all trims | |
| Seatpost | RUMBLE Escalator 34.9 mm + SL-MT500-L Hub 75 mm (dropper) | RUMBLE Escalator 34.9 mm + SL-MT500-L Hub 100 mm (dropper) |
| Brakes | Shimano BR-MT200 hydraulic disc · all trims | |
| Rear derailleur | Shimano CUES RD-U6000 · all trims | |
| Crank | SAMOX EC-53 · all trims | |
| Shifters | Shimano CUES SL-U6000 · all trims | |
| Cassette | Shimano CUES CS-LG300-10, 11-48T · all trims | |
| Chain | Shimano LinkGlide CN-LG500 · all trims | |
| Drivetrain | Shimano CUES RD-U6000; SAMOX EC-53; Shimano CUES SL-U6000; Shimano CUES CS-LG300-10, 11-48T; Shimano LinkGlide CN-LG500 · all trims | |
| Wheels | BULLS DDM-30 · all trims | |
| Tyres | Schwalbe Smart Sam K-Guard · all trims | |
| Weight | 26.4 kg | 26.8 kg |
| Price | €3,499 | €3,999 |
Rides similarly
Spot a mistake?
