Bike Finder · BH
BH iLynx+ DL Enduro
BH
iLynx+ DL Enduro 2026
CurrentFull Power · Gravity🔥 Hot · 9.2/10iFreshness 9.2/10
Motor
Avinox M2S · 150Nm · 1300W
Battery
Avinox FP800 · 800Wh
Travel F/R
180/170mm
Wheels
29F / 29R
Frame
Aluminium / Full carbon
Weight
22.4 kg
Price
From £4,900
View the BH iLynx+ DL Enduro on BH’s site
BH iLynx+ DL Enduro 2026
From £4,899
EMTB Forums verdict
The iLynx+ DL is BH's enduro flagship and the most powerful bike in the iLynx+ range, built around the DJI-derived Avinox M2S motor with a claimed 150 Nm of torque and up to 1300 W of peak power, drawing on an 800 Wh integrated battery. Travel is 170 mm at the rear from BH's Split Pivot layout, matched to a 180 mm FOX 38 fork on the top builds, so this is squarely a gravity-focused machine rather than an all-rounder.
Geometry is consistently aggressive across all four sizes: a 63.5 degree head angle, 78 degree seat angle and a fixed 450 mm chainstay, with reach growing from 445 mm on the S to 515 mm on the XL. The marketing page quotes a 77.5 degree seat angle, but the published geometry table lists 78 degrees, so treat the half-degree as a rounding difference. There is no flip chip, so the numbers are the numbers.
The six-build range spans roughly 3,300 pounds. The carbon 9.8 at 8,199.90 pounds is the showcase, with FOX Factory suspension, Shimano XTR Di2, DT Swiss H1700 wheels and a claimed 22.4 kg weight. Below it the carbon 9.7 and 9.6 keep XT Di2 shifting at lower prices, the carbon 9.5 and alloy 9.1 share an XT mechanical build at 5,499.90 pounds, and the alloy 9.0 at 4,899.90 pounds is the value entry on Deore. All six run the same M2S motor and 800 Wh battery, so the differences are frame material, suspension and finishing kit rather than drive system.
Geometry read
Size
Descending
97
Slack 63.5° head angle, 170mm travel and a long 1304mm wheelbase — composed in the chunk, confident when it gets steep, and stable through fast corners.
Playfulness
65
Short 450mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
74
Front-long in L: 854mm front centre on 450mm stays (FC:RC 1.90). Planted and composed; rewards a forward, attacking stance.
Technical climbing
80
Avinox M2S and a steep 78° seat angle keep the weight planted over the front — a proper winch. 1300W of peak power and 150Nm of torque — among the most powerful e-bike motors made.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
Watch out forL runs front-long (FC:RC 1.90).
A 854mm front centre on 450mm stays means taller riders must actively weight the front to keep it gripping. The chainstay stays 450mm on every size, so L feels more front-long than the smaller sizes.
How it stacks up vs other Full Power · Gravity bikes (from 131 bikes in the database)
Weight22.4 kg1.4 kg lighter than average
Battery800 Wh87 Wh above average
Motor torque150 Nmclass-leading torque
Value for money75/100from £4,900 · comparable bikes ~£5,889
Bike geometry diagram
SMLXL
Reach445 mm472 mm495 mm515 mm
Stack629 mm638 mm647 mm655 mm
Seattube396 mm416 mm436 mm476 mm
Chainstay450 mm450 mm450 mm450 mm
Headtube Angle63.5°63.5°63.5°63.5°
Seattube Angle (eff)78°78°78°78°
Wheelbase1245 mm1276 mm1304 mm1328 mm
Headtube110 mm120 mm130 mm140 mm
Front Centre795 mm*826 mm*854 mm*878 mm*
FC:RC1.771.841.901.95
Trims · 6
Enduro 9.0
£4,900
Enduro 9.1
£5,500
Enduro Carbon 9.5
£5,500
Enduro Carbon 9.6
£6,400
Enduro Carbon 9.7
£7,300
Enduro Carbon 9.8
£8,200
MotorAvinox M2S · 150 Nm · all trims
BatteryAvinox FP800 · 800 Wh · all trims
Travel F/R180/170 mm · all trims
FrameAluminiumAluminiumCarbonCarbonCarbonCarbon
ForkFOX 36 AWL 160mm 15QRFOX 38 FLOAT Performance 180mm 15QRFOX 36 AWL 160mm 15QRFOX 38 FLOAT Performance 180mm 15QRFOX 38 FLOAT Factory 180mm 15QRFOX 38 FLOAT Factory 180mm 15QR
ShockFOX FLOAT RhythmFOX FLOAT X PerformanceFOX FLOAT RhythmFOX FLOAT X PerformanceFOX FLOAT X FactoryFOX FLOAT X2 Factory
HeadsetAcros AIX-327 ICR · all trims
StemSatori URSA 35 · all trims
HandlebarRace Face Aeffect Riser 35, 780mm · all trims
GripsBH ErgonomicBH ErgonomicErgon GE10 EVOErgon GE10 EVOErgon GE10 EVOErgon GE10 EVO
SaddlePrologo Proxim W350 STNPrologo Proxim W350 STNPrologo Proxim W350 STNPrologo Proxim W350 STNPrologo Proxim NemboPrologo Proxim Nembo
SeatpostX-Fusion Manic dropper, 31.6mmX-Fusion Manic dropper, 31.6mmX-Fusion Manic dropper, 31.6mmX-Fusion Manic dropper, 31.6mmX-Fusion Manic dropper, 31.6mmFox Transfer Factory 31.6 (200mm dropper)
BrakesShimano MT520 4-piston, 203mm rotorsShimano MT520 4-piston, 203mm rotorsShimano MT520 4-piston, 203mm rotorsShimano XT 4-piston, 203mm rotorsShimano XT 4-piston, 203mm rotorsShimano XT 4-Piston (front and rear)
Rear derailleurShimano Deore 12spShimano XT 12spShimano XT 12spShimano XT Di2 12spShimano XT Di2 12spShimano XTR Di2 12sp
CrankE-Thirteen 34T 160mm · all trims
ShiftersShimano DeoreShimano XTShimano XTShimano XT Di2Shimano XT Di2Shimano XTR Di2
CassetteShimano CS-M6100 12sp (10-51T)Shimano CS-M6100 12sp (10-51T)Shimano CS-M6100 12sp (10-51T)Shimano CS-M6100 12sp (10-51T)Shimano CS-M8200 12sp (10-51T)Shimano CS-M9200 12sp (10-51T)
ChainShimano CN-M6100Shimano CN-M6100Shimano CN-M6100Shimano CN-M6100Shimano CN-M8100Shimano CN-M8100
DrivetrainShimano Deore 12sp; E-Thirteen 34T 160mm; Shimano Deore; Shimano CS-M6100 12sp (10-51T); Shimano CN-M6100Shimano XT 12sp; E-Thirteen 34T 160mm; Shimano XT; Shimano CS-M6100 12sp (10-51T); Shimano CN-M6100Shimano XT 12sp; E-Thirteen 34T 160mm; Shimano XT; Shimano CS-M6100 12sp (10-51T); Shimano CN-M6100Shimano XT Di2 12sp; E-Thirteen 34T 160mm; Shimano XT Di2; Shimano CS-M6100 12sp (10-51T); Shimano CN-M6100Shimano XT Di2 12sp; E-Thirteen 34T 160mm; Shimano XT Di2; Shimano CS-M8200 12sp (10-51T); Shimano CN-M8100Shimano XTR Di2 12sp; E-Thirteen 34T 160mm; Shimano XTR Di2; Shimano CS-M9200 12sp (10-51T); Shimano CN-M8100
WheelsRace Face AR 30 TR (BH hubs)Race Face AR 30 TR (BH hubs)Race Face AR 30 TR (BH hubs)Race Face AR 30 TR (BH hubs)DT Swiss H1900 TR (DT Swiss hubs)DT Swiss H1700 TR (DT Swiss hubs)
TyresMaxxis Assegai EXO TR 29x2.5 (front) / Minion Terra EXO TR 29x2.5 (rear)Maxxis Assegai EXO TR 29x2.5 (front) / Minion Terra EXO TR 29x2.5 (rear)Maxxis Assegai EXO TR 29x2.5 (front) / Minion Terra EXO TR 29x2.5 (rear)Maxxis Assegai EXO TR 29x2.5 (front) / Minion Terra EXO TR 29x2.5 (rear)Maxxis Assegai EXO TR 29x2.5 (front) / Minion Terra EXO TR 29x2.5 (rear)Maxxis Assegai TPI60 / Minion TPI120 Terra EXO TR 29x2.5/2.5
Weight22.4 kg
Price£4,900£5,500£5,500£6,400£7,300£8,200
Rides similarly
Spot a mistake?
