Bike Finder · BH
BH iLynx+
BH
iLynx+ 2025
CurrentEnduro eMTBAgeing · 4.7/10iFreshness 4.7/10
Motor
Shimano EP801 · 85Nm · 600W
Battery
BH 540Wh internal · 720Wh
Travel F/R
160/160mm
Wheels
29F / 29R
Frame
Full carbon
Weight
21.75 kg
Price
From £7,899
View the BH iLynx+ on BH’s site
BH iLynx+ 2025
From £7,899
EMTB Forums verdict
The BH iLynx+ is the full-power sibling to the lightweight iLynx+ SL, built around a carbon frame with 160 mm of Split Pivot travel front and rear on 29in wheels. It runs the Shimano EP801 motor (85 Nm) with a 540 Wh internal battery and, on most trims, the bundled XPro external bottle battery for 720 Wh total, so range can be traded for weight depending on how you set it up.
The Enduro range spans three carbon builds. The 9.7 at £7,899.90 is the value pick: a 170 mm FOX 38 Rhythm fork, Shimano XT mechanical mech with Deore shifters and MT520 four-piston brakes, though it ships as 540 Wh only without the XPro extender. The 9.8 at £8,699.90 steps up to a 160 mm FOX 38 Performance fork, full XT brakes and the 720 Wh battery package. The 9.9 Pro tops the line at £9,090.80.
Geometry is consistent and fairly classic-enduro rather than radical: a 65 degree head angle, 76 degree effective seat angle and notably short 440 mm chainstays across all four sizes (SM to XL), with reach running 430 to 492 mm. The short rear end and the BH battery layout are pitched at making a full-power bike handle more like a regular trail bike.
Bike geometry diagram
SMLXL
Reach430 mm455 mm475 mm492 mm
Stack612 mm616 mm626 mm639 mm
Seattube400 mm420 mm440 mm480 mm
Chainstay440 mm440 mm440 mm440 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)76°76°76°76°
Headtube95 mm100 mm110 mm125 mm
BB Height349 mm349 mm349 mm349 mm
Trims · 3
9.7
£7,899
9.8
£8,699
9.9 Pro
£9,090
MotorShimano EP801 · 85 Nm · all trims
BatteryBH 540Wh internal · 720 Wh · all trims
Travel F/R160/160 mm · all trims
FrameCarbon · all trims
ForkFOX 38 FLOAT Rhythm 170mm 15QRFOX 38 FLOAT Performance 160mm 15QR
ShockFOX FLOAT X PerformanceFOX FLOAT X Performance, 210x55mm
HeadsetAcros AIF-560 ICR BL.
StemBH Evo 35 FitBH Evo 35 Fit
HandlebarRace Face Aeffect Riser 35 780mmRace Face Aeffect Riser 35 780mm
GripsErgon GE10
SaddlePrologo Proxim W350 STNPrologo Proxim W450 STN
SeatpostRace Face DP Aeffect 31.6Race Face DP Aeffect 31.6
BrakesShimano MT520 4 Piston 203mm (front and rear)Shimano XT 4 Piston 203mm (front and rear)
Rear derailleurShimano XT 12spShimano XT 12sp
CrankShimano 34T SB-165mmShimano 34T SB-165mm
ShiftersShimano DeoreShimano SLX
CassetteShimano CSM6100 12sp (10-51T)Shimano CSM7100 12sp (10-51T)
ChainShimano CNM6100Shimano CNM6100
DrivetrainShimano XT 12sp; Shimano 34T SB-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; Shimano 34T SB-165mm; Shimano SLX; Shimano CSM7100 12sp (10-51T); Shimano CNM6100
WheelsRace Face Arc 30 TRRace Face Aeffect 30 TR (Race Face hubs, Stainless Steel spokes)
TyresMaxxis Minion TPI120 Terra EXO TR 29"x2.5/2.4Maxxis Minion TPI120 Terra EXO TR 29"x2.5/2.4
Weight21.75 kg
Price£7,899£8,699£9,090
Rides similarly
Spot a mistake?
