Bike Finder · BH
BH iLynx+ SL
BH
iLynx+ SL 2024
DiscontinuedLightweight eMTBLegacy · 1.7/10iFreshness 1.7/10
Motor
Shimano EP801 · 85Nm · 600W
Battery
Shimano 630Wh internal + XPro DD 180Wh
Travel F/R
140/140mm
Wheels
29F / 29R
Frame
Aluminium / Full carbon
Price
From £3,499
View the BH iLynx+ SL on BH’s site
BH iLynx+ SL 2024
From £3,499
EMTB Forums verdict
The BH iLynx+ SL was the Spanish brand's lightweight take on the full-power trail eMTB. Built around an HCIM carbon frame (BH claimed a 2.1kg frame and complete bikes from 18.8kg), it ran a Shimano EP801 motor rated at 85Nm with a 630Wh internal battery that could be supplemented by an optional XPro DD 180Wh pack for 810Wh total. The frame was offered in two configurations on the same chassis: a 140mm Trail and a 160mm Enduro, plus a more affordable alloy version.
The range split cleanly by frame and kit. Carbon trims topped out at the 6,799.90 pound Trail Carbon 8.8 and Enduro Carbon 9.8, both with FOX Factory suspension and Shimano XT Di2, while the alloy Trail 7.9 started at 3,499.90 pounds and used the lower-output EP6 motor. The Di2 carbon builds carried the cleanest electronic shifting; the XT mechanical and Deore builds covered the value end. All carbon and most alloy trims shared the EP801; only the entry alloy Trail 7.9 dropped to EP6.
Geometry was contemporary trail rather than radical, with a 78 degree seat angle and 66 degree head angle in Trail trim, short 440mm chainstays across all sizes and reach from 449mm (S) to 502mm (XL). The Enduro configuration slackened the head angle to 64 degrees, dropped the BB and lengthened the wheelbase for descending. The Split Pivot rear end and Super Boost 157x12 spacing aimed at stiffness with clearance for up to 2.5in tyres.
The iLynx+ SL is now discontinued as a 2024 model. BH has since moved its lightweight trail line toward newer iLynx platforms, so the EP801-equipped iLynx+ SL is best considered an end-of-line buy.
Bike geometry diagram
SMLXL
Reach432 mm448 mm468 mm485 mm
Stack613 mm621 mm628 mm636 mm
Seattube400 mm420 mm440 mm480 mm
Chainstay440 mm440 mm440 mm440 mm
Headtube Angle64°64°64°64°
Seattube Angle (eff)76°76°76°76°
Wheelbase1206 mm1226 mm1250 mm1273 mm
Headtube90 mm100 mm110 mm125 mm
BB Height346 mm346 mm346 mm346 mm
Standover756 mm772 mm789 mm814 mm
Front Centre766 mm*786 mm*810 mm*833 mm*
Trims · 10
Trail 7.9
£3,499
Trail 8.0
£4,299
Enduro 9.0
£4,399
Enduro 9.1
£4,899
Enduro Carbon 9.6
£4,999
Trail Carbon 8.6
£4,999
Enduro Carbon 9.7
£5,899
Trail Carbon 8.7
£5,899
Enduro Carbon 9.8
£6,799
Trail Carbon 8.8
£6,799
MotorShimano EP6 (DU-EP600) · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 NmShimano EP801 · 85 Nm
BatteryShimano 630Wh internal + XPro DD 180Wh · 630 Wh · all trims
Travel F/R140/140 mm · all trims
FrameAluminiumAluminiumAluminiumAluminiumCarbonCarbonCarbonCarbonCarbonCarbon
ForkRockShox Recon RL Air 150mmRockShox Psylo 160mm 15QRFOX 36 FLOAT Rhythm 170mm 15QRFOX 38 FLOAT Factory 170mm 15QRFOX 36 FLOAT Factory 140mm 15QR
ShockFOX FLOAT X FactoryFOX FLOAT X Performance
HandlebarRace Face
SaddlePrologo Proxim W450 Stn
SeatpostRace Face DP Aeffect 31.6 (SM 100mm, MD 150mm, LA 150mm, XL 170mm)
BrakesShimano XT 4 Piston (front and rear)Shimano XT 4 Piston (front and rear)
Rear derailleurShimano Deore 10spShimano Deore 12spShimano Deore 12spShimano XT 12spShimano XT 12spShimano XT 12spShimano XT DI2 12spShimano XT DI2 12spShimano XT DI2 12spShimano XT DI2 12sp
CrankShimano XT 34T SB -160mmShimano XT 34T SB -160mm
ShiftersShimano Deore 10spShimano Deore 12spShimano Deore 12spShimano XT 12spShimano XT 12spShimano XT 12spShimano XT DI2 12spShimano XT DI2 12spShimano XT DI2Shimano XT DI2
CassetteShimano CS-M8200 12sp (10-51T)Shimano CS-M8200 12sp (10-51T)
ChainShimano CN-M8100Shimano CN-M8100
DrivetrainShimano Deore 10sp; Shimano Deore 10spShimano Deore 12sp; Shimano Deore 12spShimano Deore 12sp; Shimano Deore 12spShimano XT 12sp; Shimano XT 12spShimano XT 12sp; Shimano XT 12spShimano XT 12sp; Shimano XT 12spShimano XT DI2 12sp; Shimano XT DI2 12spShimano XT DI2 12sp; Shimano XT DI2 12spShimano XT DI2 12sp; Shimano XT 34T SB -160mm; Shimano XT DI2; Shimano CS-M8200 12sp (10-51T); Shimano CN-M8100Shimano XT DI2 12sp; Shimano XT 34T SB -160mm; Shimano XT DI2; Shimano CS-M8200 12sp (10-51T); Shimano CN-M8100
WheelsRace Face ACR30 TRRace Face ACR30 TRRace Face ACR30 TRRace Face Turbine 30 TR (Race Face hubs)Race Face Turbine 30 TR (Race Face hubs, stainless steel spokes)
TyresMaxxis Assegai TPI60 (front) / Minion TPI120 Terra EXO TR 29x2.5/2.4Maxxis Minion TPI120 Terra EXO TR 29x2.5/2.4
Price£3,499£4,299£4,399£4,899£4,999£4,999£5,899£5,899£6,799£6,799
Rides similarly
Spot a mistake?
