Bike Finder · BH
BH iLynx+ DL Trail
BH
iLynx+ DL Trail 2026
CurrentFull Power · Trail🔥 Hot · 10/10iFreshness 10/10
Full-power Avinox trail bike kept light and priced to undercut rivals
Motor
Avinox M2S · 150Nm · 1300W
Battery
Avinox FP800 · 800Wh
Travel F/R
150/140mm
Wheels
29F / 29R
Frame
Aluminium / Carbon front, aluminium rear
Weight
21 kg
Price
From £3,500
View the BH iLynx+ DL Trail on BH’s site
BH iLynx+ DL Trail 2026
From £3,499
EMTB Forums verdict
The iLynx+ DL Trail is BH's new dedicated 140mm trail chassis in the iLynx+ DL family, launched July 2026 alongside the 170mm Enduro sibling. It is a genuinely separate frame, not a travel-adjusted Enduro: 140mm rear Split Pivot with a 150mm fork (140mm on the base build), its own geometry (65 degree head angle versus the Enduro's 63.5, with a 78 degree seat angle on both) and shorter 447mm stays. All six builds get the same 800Wh battery, and every build bar the base runs the DJI-made Avinox M2S with 150Nm and 1300W peak, which is standout drive-unit spec at these prices.
  • Value: the range starts at 3,499.90 GBP for the alloy Trail 7.9, an aggressive entry price for an 800Wh Avinox bike, though note the 7.9 runs the older Avinox M2 motor, a 10-speed Deore drivetrain and an SR Suntour XCR34 fork.
  • Sweet spots: the Trail 8.1 (4,999.90 GBP) is the top alloy build with FOX 36 AWL, Float Rhythm and XT shifting; the Trail Carbon 8.7 (6,399.90 GBP) adds the full-carbon frame, Fox 36 Performance, Float X and XT Di2 shifting.
  • Flagship: the Trail Carbon 8.8 (7,299.90 GBP) gets a Factory-level 36, XT Di2 with the CSM8200 cassette and DT Swiss H1900 wheels at a claimed 21kg.
  • Geometry: roomy for a trail bike, with 440 to 520mm reach across S to XL on the carbon frame, 29in wheels front and rear, and 203mm rotors on every build.
This bike launched in July 2026, so there is no owner feedback or long-term reliability data on the forum yet; the above is based purely on BH's published specifications.
Geometry read
Size
Setting
Descending
63
A solid all-round descender (65° head angle, 140mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
79
Short 447mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
82
Balanced front-to-rear in L (FC:RC 1.86) — weight sits evenly between the wheels.
Technical climbing
89
Avinox M2S and a steep 78° seat angle keep the weight planted over the front — a proper winch. 1300W of peak power and 150Nm of torque — among the most powerful e-bike motors made.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
How it stacks up vs other Full Power · Trail bikes (from 271 bikes in the database)
Weight21 kg2.0 kg lighter than average
Battery800 Wh95 Wh above average
Motor torque150 Nmclass-leading torque
Value for money92/100from £3,500 · comparable bikes ~£4,860
💬 Forum discussion
WHO makes this SL Trail/All-Mountain ebike?
12 replies · 942 views · last reply 2 months ago
Join the discussion →
Bike geometry diagram
Flip-chip position
geometry changes with the chip
SMLXL
Reach450 mm470 mm495 mm520 mm
Stack629 mm634 mm648 mm657 mm
Seattube400 mm420 mm440 mm480 mm
Chainstay447 mm447 mm447 mm447 mm
Headtube Angle65°65°65°65°
Seattube Angle (eff)77°77°77°77°
Wheelbase1224 mm1246 mm1278 mm1307 mm
Headtube110 mm115 mm130 mm140 mm
BB Height350 mm350 mm350 mm350 mm
Standover810 mm808 mm808 mm808 mm
Front Centre777 mm*799 mm*831 mm*860 mm*
FC:RC1.741.791.861.92
Trims · 6
Trail 7.9
£3,500
Trail 8.0
£4,200
Trail 8.1
£5,000
Trail Carbon 8.6
£5,500
Trail Carbon 8.7
£6,400
Trail Carbon 8.8
£7,300
MotorAvinox M2 · 150 NmAvinox M2S · 150 NmAvinox M2S · 150 NmAvinox M2S · 150 NmAvinox M2S · 150 NmAvinox M2S · 150 Nm
BatteryAvinox FP800 · 800 Wh · all trims
Travel F/R150/140 mm · all trims
FrameAlloyAlloyAlloycarbon front triangle (BCL Carbon), alloy rear trianglecarbon (Ballistic Carbon Layup, Hollow Core Internal Molding); alloy on lower trims (see per-trim overrides)carbon (Ballistic Carbon Layup, Hollow Core Internal Molding); alloy on lower trims (see per-trim overrides)
ForkSR Suntour XCR34 Air 140mm 15QRRock Shock Recon RL Air 150mm (RockShox, as printed by BH)FOX 36 AWL 150mm 15QRFOX 36 AWL 150mm 15QRFOX 36 FLOAT Performance 150mm 15QRFOX 36 FLOAT Factory 150mm 15QR
ShockRock Shox Deluxe DebonairRock Shox Deluxe DebonairFOX FLOAT RhythmFOX FLOAT RhythmFOX FLOAT X PerformanceFOX FLOAT X Performance
HeadsetAcros AIX287 ICR BL.Acros AIX287 ICR BL.Acros AIX287 ICR BL.Acros AIX327 ICR BL.Acros AIX327 ICR BL.Acros AIX327 ICR BL.
StemSatori URSA 35 · all trims
HandlebarBH MTB SLite Alloy Riser 780mmRace Face Aeffect Riser 35, 780mmRace Face Aeffect Riser 35, 780mmRace Face Aeffect Riser 35, 780mmRace Face Aeffect Riser 35, 780mmRace Face Aeffect Riser 35, 780mm
GripsBH ErgonomicBH ErgonomicBH ErgonomicErgon GE10 EVOErgon GE10 EVOErgon GE10 EVO
SaddlePrologo Proxim W350 StnPrologo Proxim W350 StnPrologo Proxim W350 StnPrologo Proxim W350 StnPrologo Proxim W350 StnPrologo Proxim Nembo
SeatpostXFusion Manic TA 31.6 dropper · all trims
BrakesShimano MT420 4 Piston (front and rear)Shimano MT420 4 Piston (front and rear)Shimano MT520 4 Piston (front and rear)Shimano MT520 4 Piston (front and rear)Shimano XT 4 Piston (front and rear)Shimano XT 4 Piston (front and rear)
Rear derailleurShimano Deore 10spShimano Deore 12spShimano XT 12spShimano XT 12spShimano XT DI2 12spShimano XT DI2 12sp
CrankEThirteen 34T 160mm · all trims
ShiftersShimano DeoreShimano DeoreShimano DeoreShimano DeoreShimano Deore DI2Shimano XT DI2
CassetteShimano CSM4100 10sp (11-46T)Shimano CSM6100 12sp (10-51T)Shimano CSM6100 12sp (10-51T)Shimano CSM6100 12sp (10-51T)Shimano CSM6100 12sp (10-51T)Shimano CSM8200 12sp (10-51T)
ChainShimano HG54Shimano CNM6100Shimano CNM6100Shimano CNM6100Shimano CNM6100Shimano CNM8100
DrivetrainShimano Deore 10sp; EThirteen 34T 160mm; Shimano Deore; Shimano CSM4100 10sp (11-46T); Shimano HG54Shimano Deore 12sp; EThirteen 34T 160mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; EThirteen 34T 160mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT 12sp; EThirteen 34T 160mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT DI2 12sp; EThirteen 34T 160mm; Shimano Deore DI2; Shimano CSM6100 12sp (10-51T); Shimano CNM6100Shimano XT DI2 12sp; EThirteen 34T 160mm; Shimano XT DI2; Shimano CSM8200 12sp (10-51T); Shimano CNM8100
WheelsBH Lite Mach1 Trucky 30 wheelset, BH hubs, stainless steel spokesBH Lite Mach1 Trucky 30 wheelset, BH hubs, stainless steel spokesRace Face Ar 30 TR wheelset, BH hubs, stainless steel spokesRace Face Ar 30 TR wheelset, BH hubs, stainless steel spokesDT Swiss H1900 TR wheelset, DT Swiss hubs, stainless steel spokesDT Swiss H1900 TR wheelset, DT Swiss hubs, stainless steel spokes
TyresMaxxis Minion TPI120 Terra EXO TR 29"x2.5/2.4 · all trims
Weight21 kg
Price£3,500£4,200£5,000£5,500£6,400£7,300
Rides similarly
Spot a mistake?
