A solid all-round descender (66° head angle, 150mm) — capable in the rough and steep without being an all-out bruiser.
iLynx Trail Carbon 2022
The 2022 BH iLynx Trail Carbon launched as BH's lightweight carbon trail eMTB built around the brand's own 2EXMAG motor, rated at 65 Nm and 250 W with assistance to 110 rpm and operated through BH's iRemote rather than a screen. It pairs 150 mm of travel front and rear with a Split Pivot single-pivot layout, 29in wheels and a 540 Wh internal battery that can be topped up by an optional 180 Wh XPro range-extender bottle for up to 720 Wh. Geometry is moderate-modern for the era: a 66 degree head angle, a 75.5 degree effective seat angle, short 451 mm chainstays across all sizes and reach running from 427 mm on the S to 488 mm on the XL over four sizes.
Four trims were offered, all sharing the same frame, motor, geometry and 540 Wh battery, so the differences are entirely suspension grade, drivetrain finish and wheels. The 8.6 at GBP 6,499.90 covers the basics with a FOX 36 Performance fork, FLOAT DPS Performance shock, Shimano MT420 four-piston brakes and Deore shifting. The 8.7 at GBP 7,499.90 steps up to a FOX 36 Factory fork, FLOAT X Factory shock, full XT four-piston brakes and SLX shifting. The Carbon Pro 8.8 at GBP 8,299.90 adds full XT shifting, an FSA carbon crank and Race Face Turbine wheels, and the range-topping Carbon Pro 8.9 at GBP 8,999.90 brings a full Shimano XTR drivetrain and a Fox Transfer Factory dropper.
Because the frame and geometry are common across the range, value hinges on how much fork and damper grade, drivetrain finish and wheel quality matter to you rather than on capability. The 540 Wh pack is modest for the travel, which is where the XPro extender earns its place on longer days.
This generation is discontinued. BH later updated the iLynx Trail Carbon platform with a larger internal battery and a revised version of its 2EXMAG motor, so the bikes here are the earlier 540 Wh launch version of the family.
Rear-long with a planted front in L (FC:RC 1.74) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Climbs well — a 75.5° seat keeps the front planted. 500W of peak power and 65Nm of torque.
How it stacks up vs other Lightweight · Trail bikes (from 87 bikes in the database)
| S | M | L | XL | |
| Reach | 427 mm | 453 mm | 473 mm | 488 mm |
| Stack | 609 mm | 615 mm | 624 mm | 638 mm |
| Seattube | 400 mm | 410 mm | 440 mm | 480 mm |
| Chainstay | 451 mm | 451 mm | 451 mm | 451 mm |
| Headtube Angle | 66° | 66° | 66° | 66° |
| Seattube Angle (eff) | 75.5° | 75.5° | 75.5° | 75.5° |
| Wheelbase | 1183 mm | 1210 mm | 1234 mm | 1255 mm |
| Headtube | 95 mm | 100 mm | 110 mm | 125 mm |
| BB Height | 339 mm | 339 mm | 339 mm | 339 mm |
| Front Centre | 732 mm* | 759 mm* | 783 mm* | 804 mm* |
| FC:RC | 1.62 | 1.68 | 1.74 | 1.78 |
Trims · 4
8.6 £6,500 | 8.7 £7,500 | Carbon Pro 8.8 £8,300 | Carbon Pro 8.9 £9,000 | |
| Motor | BH BHZ · 65 Nm · all trims | |||
| Battery | BH 540 · 540 Wh · all trims | |||
| Travel F/R | 150/150 mm · all trims | |||
| Frame | Carbon · all trims | |||
| Fork | FOX 36 FLOAT Performance 150mm 15QR | FOX 36 FLOAT Factory 150mm 15QR | FOX 36 FLOAT Factory 150mm 15QR | FOX 36 FLOAT Factory 150mm 15QR |
| Shock | FOX FLOAT DPS Performance, 150mm | FOX FLOAT X Factory, 150mm | FOX FLOAT X Factory, 150mm | FOX FLOAT X Factory, 150mm |
| Headset | Acros AIF-543 ICR BL. · all trims | |||
| Stem | BH Evo 35 Fit · all trims | |||
| Handlebar | Race Face Aeffect Riser 35 780mm · all trims | |||
| Grips | Ergon GE10 | Ergon GE10 | Ergon GE10 | Ergon GE1-Factory |
| Saddle | Prologo Proxim W350 Stn | Prologo Proxim W450 Stn | Prologo Proxim W450 Stn | Prologo Proxim W450 Stn |
| Seatpost | Race Face DP Aeffect 31.6 dropper | Race Face DP Aeffect 31.6 dropper | Race Face DP Aeffect 31.6 dropper | Fox Transfer Factory 31.6 dropper |
| Brakes | Front: Shimano MT420 4 Piston, Rear: Shimano MT420 4 Piston | Front: Shimano XT 4 Piston 203mm, Rear: Shimano XT 4 Piston 203mm | Front: Shimano XT 4 Piston 203mm, Rear: Shimano XT 4 Piston 203mm | Front: Shimano XT 4 Piston 203mm, Rear: Shimano XT 4 Piston 203mm |
| Rear derailleur | Shimano XT 12sp | Shimano XT 12sp | Shimano XT 12sp | Shimano XTR 12sp |
| Crank | FSA 34T SB-165mm | FSA 34T SB-165mm | FSA Carbon 34T SB-165mm | FSA Carbon 34T SB-165mm |
| Shifters | Shimano Deore | Shimano SLX | Shimano XT | Shimano XTR |
| Cassette | Shimano CS-M6100 12sp (10-51T) | Shimano CS-M7100 12sp (10-51T) | Shimano CS-M8100 12sp (10-51T) | Shimano CS-M9100 12sp (10-51T) |
| Chain | Shimano CN-M6100 | Shimano CN-M6100 | Shimano CN-M6100 | Shimano CN-M9100 |
| Drivetrain | Shimano XT 12sp; FSA 34T SB-165mm; Shimano Deore; Shimano CS-M6100 12sp (10-51T); Shimano CN-M6100 | Shimano XT 12sp; FSA 34T SB-165mm; Shimano SLX; Shimano CS-M7100 12sp (10-51T); Shimano CN-M6100 | Shimano XT 12sp; FSA Carbon 34T SB-165mm; Shimano XT; Shimano CS-M8100 12sp (10-51T); Shimano CN-M6100 | Shimano XTR 12sp; FSA Carbon 34T SB-165mm; Shimano XTR; Shimano CS-M9100 12sp (10-51T); Shimano CN-M9100 |
| Wheels | Race Face Aeffect 30 TR | Race Face Aeffect 30 TR | Race Face Turbine 30 TR | Race Face Turbine 30 TR |
| Tyres | Maxxis Minion TPI120 Terra EXO TR 29 x 2.5/2.4 · all trims | |||
| Price | £6,500 | £7,500 | £8,300 | £9,000 |
Rides similarly
Spot a mistake?
