Steeper 67.7° and shorter travel — happiest descending smooth, flowy trail rather than properly rough or steep terrain.
iLynx Race Carbon 2022
Pure cross-country racer built for fast, efficient miles
The 2022 BH iLynx Race Carbon was BH's lightweight XC and marathon race eMTB, sharing its HCIM monocoque carbon frame (Toray T1100 and T800 fibres, claimed 2,200g with shock) with BH's high-end road bikes. For 2022 it adopted BH's newly developed in-house 2EXMAG drive, a compact 2.1kg unit quoted at 65Nm, 250W, 110rpm and 163mm Q-factor and described by BH as 10 per cent lighter than the previous 2ESMAG. A 540Wh internal battery was standard on the LT trims and could be topped up to 720Wh via the optional XPro add-on pack.
The range spanned four trims. The LT 7.6 paired a FOX 34 Performance 120mm fork with Shimano XT mechanical shifting and MT420 brakes at GBP 6,299.90, while the LT 7.7 stepped up to a FOX 34 Factory Step-Cast fork, full XT and alloy wheels at GBP 7,299.90. The Pro LT 7.8 added Shimano XTR, FOX Factory damping, carbon wheels and the 720Wh battery at GBP 8,299.90, and the flagship Pro 7.9 dropped to a 100mm race set-up with a FOX 34 Factory SC remote fork, SRAM XX1 AXS wireless shifting and the 720Wh pack for GBP 9,299.90.
Geometry was firmly XC-orientated for its era and varied by build. The 120mm Performance-forked LT 7.6 and the 100mm Pro 7.9 used a 67.7 degree head angle and 74.7 degree seat angle (reach 412/431/451mm); the Factory-forked LT 7.7 and Pro LT 7.8 ran a slightly steeper 68.5 degree head angle and 75.5 degree seat angle (reach 420/439/458mm). Chainstays were a short 453mm across all builds, and the bike was offered in S, M and L only. This generation is now discontinued. BH carried the same 7.x lineup into 2023 before later moving the iLynx Race Carbon onto a lighter platform with a 630Wh battery and the rebranded 65Nm BHZ drive.
Not enough geometry on record to judge size balance.
A workmanlike climber — expect to put in more rider effort on the steep stuff. 500W of peak power and 65Nm of torque.
Fine at trail pace; it'll feel out of its depth on properly rough, steep tracks.
How it stacks up vs other Lightweight · Cross-Country bikes (from 70 bikes in the database)
| S | M | L | |
| Reach | 412 mm | 431 mm | 451 mm |
| Stack | 598 mm | 605 mm | 612 mm |
| Seattube | 400 mm | 440 mm | 480 mm |
| Chainstay | 453 mm | 453 mm | 453 mm |
| Headtube Angle | 67.7° | 67.7° | 67.7° |
| Seattube Angle (eff) | 74.7° | 74.7° | 74.7° |
| Headtube | 100 mm | 110 mm | 120 mm |
Trims · 4
LT 7.6 £6,300 | LT 7.7 £7,300 | Pro LT 7.8 £8,300 | Pro 7.9 £9,300 | |
| Motor | BH BHZ · 65 Nm · all trims | |||
| Battery | BH 540Wh (XPro range-extender to 720Wh) · 540 Wh · all trims | |||
| Travel F/R | 120/120 mm · all trims | |||
| Frame | Carbon · all trims | |||
| Fork | FOX 34 FLOAT Performance 120mm 15QR | FOX 34 FLOAT Factory SC 120mm 15QR | FOX 34 FLOAT Factory SC 120mm 15QR | FOX 34 FLOAT Factory SC Rem 100mm 15QR |
| Shock | FOX FLOAT DPS Performance | FOX FLOAT DPS Performance | FOX FLOAT DPS Factory | FOX FLOAT DPS Factory Rem |
| Headset | Acros AIF-543 ICR BL. · all trims | |||
| Stem | BH Evo 31 Fit · all trims | |||
| Handlebar | BH MTB Lite Alloy Riser 780mm | BH MTB SLite Alloy Riser 780mm | BH Evo Carbon Riser 760mm | BH Evo Carbon Riser 760mm |
| Grips | Ergon GE10 | Ergon GE1-Factory | Ergon GE1-Factory | Ergon GE1-Factory |
| Saddle | Prologo Proxim W350 Stn | Prologo Scratch M5 Stn | Prologo Scratch M5 Stn | Prologo Scratch M5 Stn |
| Seatpost | Race Face DP Aeffect 31.6 | Bike Yoke Divine 31.6 | Bike Yoke Divine 31.6 | BH Evo Carbon 31.6 |
| Brakes | Shimano MT420 4 Piston (front and rear) | Shimano XT 4 Piston 203mm (front and rear) | Shimano XT 4 Piston 203mm (front and rear) | Shimano XT 4 Piston 203mm (front and rear) |
| Rear derailleur | Shimano XT 12sp | Shimano XT 12sp | Shimano XTR 12sp | Sram XX1 AXS Eagle 12SP |
| Crank | FSA 34T-165mm | FSA 34T-165mm | FSA Carbon 34T 165mm | FSA Carbon 34T 165mm |
| Shifters | Shimano Deore | Shimano XT | Shimano XT | Sram XX1 AXS Eagle |
| Cassette | Shimano CSM6100 12sp (10-51T) | Shimano CSM8100 12sp (10-51T) | Shimano CSM8100 12sp (10-51T) | Sram XX1 Eagle 12sp (10-52T) |
| Chain | Shimano CNM6100 | Shimano CNM6100 | Shimano CNM6100 | Sram XX1 Eagle |
| Drivetrain | Shimano XT 12sp; FSA 34T-165mm; Shimano Deore; Shimano CSM6100 12sp (10-51T); Shimano CNM6100 | Shimano XT 12sp; FSA 34T-165mm; Shimano XT; Shimano CSM8100 12sp (10-51T); Shimano CNM6100 | Shimano XTR 12sp; FSA Carbon 34T 165mm; Shimano XT; Shimano CSM8100 12sp (10-51T); Shimano CNM6100 | Sram XX1 AXS Eagle 12SP; FSA Carbon 34T 165mm; Sram XX1 AXS Eagle; Sram XX1 Eagle 12sp (10-52T); Sram XX1 Eagle |
| Wheels | Race Face Ar 30 TR wheelset (BH hubs, stainless steel spokes) | BH Evo A30 Alu TR wheelset (BH Evo hubs, stainless steel spokes) | BH Evo C30 Carbon TR wheelset (BH Evo hubs, stainless steel spokes) | BH Evo C30 Carbon TR wheelset (BH Evo hubs, stainless steel spokes) |
| Tyres | Maxxis Ardent/Ikon TPI120 MaxxSpeed EXO TR 29x2.35 · all trims | |||
| Price | £6,300 | £7,300 | £8,300 | £9,300 |
Rides similarly
Spot a mistake?
