Bike Finder · BH
BH XTEP Lynx Carbon Pro
BH
XTEP Lynx Carbon Pro 2023
DiscontinuedFull Power · EnduroLegacy · 1/10iFreshness 1/10
Travel F/R
160/160mm
Wheels
29F / 29R
Frame
Full carbon
Weight
Price
From £7,199
View the BH XTEP Lynx Carbon Pro on BH’s site
BH XTEP Lynx Carbon Pro 2023
From £7,199
EMTB Forums verdict
The BH XTEP Lynx Carbon Pro is BH's MY2023 carbon enduro eMTB, the longer-travel sibling to the trail-oriented AtomX Lynx. It pairs a full-carbon X System frame with 160mm of Split Pivot rear travel and a matching 160mm fork, driven by Shimano's EP801 motor (85 Nm) and a 720Wh battery using 21700 cells for a claimed range of up to 155km.
The carbon line ran across three Pro trims (9.7, 9.8, 9.9), spanning roughly £7,199 to £8,999. The 9.7 and 9.8 run a FOX 36 Performance fork, stepping from a FOX Float DPS to a Float X shock and from Shimano MT520 to XT four-piston brakes; the flagship 9.9 adds a FOX 38 Factory fork and a Float DHX2 Factory coil shock. All trims share 29in wheels and Maxxis Minion enduro rubber. Geometry is aggressive-trail to enduro: a 65.1 to 65.6 degree head angle, 73.7 degree effective seat angle, a short 465mm chainstay and wheelbases from 1213mm (S) to 1264mm (L and XL).
It is distinct from the BH AtomX Lynx Carbon of the same year, which is a 150/150mm trail bike on a Brose Drive S Mag motor. The XTEP name has since been retired as BH consolidated its eMTB range under the iLynx naming, so this model is discontinued.
Geometry read
Size
Descending
65
A solid all-round descender (65.6° head angle, 160mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
24
More planted than poppy — better on steep terrain than tight, fiddly singletrack.
Size balance
86
Rear-long with a planted front in L (FC:RC 1.72) — easy to weight the front and quick to turn, though it can feel light at the back at real speed.
Technical climbing
72
Shimano EP801 and a steep 73.7° seat angle keep the weight planted over the front — a proper winch. 600W of peak power and 85Nm of torque — a strong full-power motor.
Best suited toBig-day all-rounders who climb a lot and still descend hard.
Strong up and composed down — a do-it-all, not a specialist.
Watch out forNot a flickable, playful bike — built to plough, not pop.
Brilliant on fast, rough, steep terrain; less fun on tight, mellow trails.
How it stacks up vs other Full Power · Enduro bikes (from 132 bikes in the database)
Battery720 Whabout average capacity
Motor torque85 Nm18 Nm below average
Value for money56/100from £7,199 · most Shimano EP801 bikes ~£7,500
Bike geometry diagram
SMLXL
Reach421 mm431 mm461 mm461 mm
Stack608 mm620 mm647 mm647 mm
Seattube400 mm400 mm440 mm480 mm
Chainstay465 mm465 mm465 mm465 mm
Headtube Angle65.1°65.6°65.6°65.6°
Seattube Angle (eff)73.7°73.7°73.7°73.7°
Wheelbase1213 mm1222 mm1264 mm1264 mm
Headtube100 mm110 mm125 mm140 mm
Front Centre748 mm*757 mm*799 mm*799 mm*
FC:RC1.611.631.721.72
Trims · 3
Carbon Pro 9.7
£7,199
Carbon Pro 9.8
£7,899
Carbon Pro 9.9
£8,999
MotorShimano EP801 · 85 Nm · all trims
BatteryBH XTEP 720Wh · 720 Wh · all trims
Travel F/R160/160 mm · all trims
FrameCarbon · all trims
ForkFOX 36 FLOAT Performance 160mm 15QRFOX 36 FLOAT Performance 160mm 15QRFOX 38 FLOAT Factory 160mm 15QR
ShockFOX FLOAT DPS PerformanceFOX FLOAT X PerformanceFOX FLOAT DHX2 Factory
HeadsetAcros AIX-545 ICR IPS · all trims
StemBH Evo 35 Fit · all trims
HandlebarRace Face Aeffect Riser 35 780mm · all trims
GripsErgon GE10Ergon GE10Ergon GE1-Factory
SaddlePrologo Proxim W350 StnPrologo Proxim W450 StnPrologo Proxim W450 Stn
SeatpostRace Face DP Aeffect 31.6 · all trims
BrakesShimano MT520 4-piston hydraulic disc, 203mm front / 203mm rearShimano XT 4-piston hydraulic disc, 203mm front / 203mm rearShimano XT 4-piston hydraulic disc, 203mm front / 203mm rear
Rear derailleurShimano XT 12sp · all trims
CrankShimano 34T 165mm · all trims
ShiftersShimano DeoreShimano SLXShimano XT
CassetteShimano CS-M6100 12sp (10-51T)Shimano CS-M7100 12sp (10-51T)Shimano CS-M8100 12sp (10-51T)
ChainShimano CN-M6100Shimano CN-M7100Shimano CN-M6100
DrivetrainShimano XT 12sp; Shimano 34T 165mm; Shimano Deore; Shimano CS-M6100 12sp (10-51T); Shimano CN-M6100Shimano XT 12sp; Shimano 34T 165mm; Shimano SLX; Shimano CS-M7100 12sp (10-51T); Shimano CN-M7100Shimano XT 12sp; Shimano 34T 165mm; Shimano XT; Shimano CS-M8100 12sp (10-51T); Shimano CN-M6100
WheelsRace Face AR 30 TR wheelset, BH hubsDT Swiss H1900 TR wheelset, DT Swiss hubsDT Swiss H1700 TR wheelset, DT Swiss hubs
TyresMaxxis Minion TPI120 Terra EXO TR 29" · all trims
Price£7,199£7,899£8,999
Rides similarly
Spot a mistake?
