Bike Finder · Amflow
Amflow PX Carbon
Amflow
PX Carbon 2026
CurrentFull Power eMTB🔥 Hot · 10/10iFreshness 10/10
Mature Avinox lightweight all-rounder
Motor
Avinox M2S · 150Nm · 1500W
Battery
Avinox FP700 · 700Wh
Travel F/R
160/150mm
Wheels
29 OR mullet (29F/27.5R) — rider choice
Frame
Full carbon
Weight
21.4 kg
Price
From £6,499
View the Amflow PX Carbon on Amflow’s site
Amflow PX Carbon 2026
From £6,499
EMTB Forums verdict
The Amflow PX Carbon 2026 is a full-power carbon eMTB built around the new DJI Avinox M2S drive unit, with 150 mm rear travel, a 160 mm fork and a permanently integrated 700 Wh battery. Headline numbers tell the story: 150 Nm peak torque, a claimed 1500 W in Boost, a 21.4 kg quoted weight and a 64.2 degree head angle that pairs with a reach range of 455 to 528 mm across four sizes. The community verdict is that this is the most mature Avinox bike yet, with @BikingBad noting the second-generation system feels far more polished than the original.
Drive system and range. The Avinox M2S is rated 250 W nominal with a claimed 1500 W peak and 150 Nm of torque in Boost, dropping to a 130 Nm continuous figure in Turbo. @robikinkela reports ECO mode delivers a usable 40 Nm and 350 W ceiling, which is plenty for long pedalable links between descents. The 700 Wh FP700 battery is integrated and not removable, charged by a 12 A 508 W fast charger per @BikingBad. Forum debate has been spiky on the non-removable pack, with @B-man arguing big-vert riders need swappable cells, while @Wojtek counters that a removable cradle adds weight and shrinks range. Treat 700 Wh as a one-tank-only deal.
Geometry and handling. A single 64.2 degree head angle runs across the range, slacker than the 65 degree trail norm but not extreme. Reach steps cleanly from 455 mm on M to 478 mm on L, 503 mm on XL and 528 mm on XXL, with wheelbase climbing 1231 mm to 1322 mm. The four chainstay flip-chip positions let you set 438 mm or 451 mm regardless of frame size, and the bike ships happy on full 29 or mullet without affecting CS or BB choices. Forty geometry configurations sound gimmicky, but in practice you have five head-angle inserts, two BB heights and four CS positions to actually dial in.
Build and value. Two trims and a tight ladder. The base at £6499 brings a FOX 36 Performance with GRIP damper, Float X Performance shock, Magura Gustav Pro four-piston brakes on 203 mm 2.5 mm rotors and a SRAM S1000 Eagle Transmission. The Pro at £8999 swaps in FOX Factory Kashima 36 with GRIP X2, Factory Float X and SRAM X0 AXS Transmission. Brakes and wheels are unchanged, which makes the base look like the value pick if you can live without Kashima.
Community-verified strengths. Owners praise the smoothness of the second-generation Avinox power delivery, with @BikingBad highlighting the 2-inch OLED top-tube screen and dual wireless bar remotes as a step above most rivals. The 21.4 kg quoted weight punches well below typical 150 Nm full-power rivals. Geometry adjustability earns repeated praise: most riders pick their setup once and never touch it again, but the option is there.
Caveats and known gripes. Three flags. First, the integrated 700 Wh pack means no field swaps, full stop. Second, dropper compatibility is tight: @NicolasC76 found the size L seat tube offers only 270 mm of clearance, short of the 292.7 mm a 175 mm Fox Transfer Neo Factory needs. Third, the Magura Gustav Pro rotors are a proprietary 2.5 mm thickness and the rear disc doubles as the speed sensor, which @NicolasC76 flags as a constraint when swapping to aftermarket brakes.
Verdict. If you want the most powerful, lightest, most adjustable full-power eMTB on sale and you can stomach a fixed battery and proprietary brake rotors, this is the bike to beat. Currently shipping in Europe and Australia with no confirmed US date and ongoing FCC complications for DJI imports stateside. Production status is current.
💬 Forum discussion
New Amflow PX April 9 specs
95 replies · 16.7k views · last reply 5 weeks ago
Join the discussion →
“I love how people just spit info out like its a fact and have no supporting documentation”
— TTEngineer · ♥ 13 · most-liked post
OWNERS’ REPORT
Amflow PX — what owners actually know
252 posts · 110 owners · data through Jun 2026
3Spares pipeline not yet live (rotors, crown race) · typical onset: First wheel upgrade or service
2M2S rattle lottery reaches the PX (also tracked in the Avinox M2S report) · typical onset: First rides
1Website-direct purchase refund risk · typical onset: At cancellation/refund
3 weeks in (PX Pro): 'a step up from the PL Pro in every area... climbs way better... zero rattle... power delivery feels much more natural than the M1' - and…
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Frame
Ultra-light full carbon frame (2.4 kg) with four-bar suspension, 150 mm rear travel paired with a 160 mm fork. 40 geometry configurations via 5 head-tube-angle inserts, 2 BB height positions and 4 chainstay lengths. Permanently integrated 700 Wh battery in the downtube. Top-tube-integrated 2-inch OLED touchscreen, dual wireless bar remotes, fully integrated front and rear lights, 1.5IS lower headset, mullet-ready (ships 29/27.5).
Bike geometry diagram
MLXLXXL
Toptube586.9 mm619.7 mm642.8 mm672.2 mm
Reach455 mm478 mm503 mm528 mm
Stack622.1 mm632.2 mm645.9 mm659 mm
Seattube415 mm427 mm447 mm466 mm
Chainstay451 mm451 mm451 mm451 mm
Headtube Angle64.2°64.2°64.2°64.2°
Seattube Angle (eff)78°78°78°77.7°
BB Drop23.7 mm23.7 mm23.7 mm23.7 mm
Wheelbase1231.3 mm1259.1 mm1290.2 mm1322.1 mm
Headtube109 mm120 mm135 mm150 mm
BB Height345.5 mm345.5 mm345.5 mm345.5 mm
Standover780 mm785 mm790 mm795 mm
Front Centre793.1 mm820.9 mm852 mm883.9 mm
Trims · 2
Carbon
£6,499
Pro
£8,999
MotorAvinox M2S · 150 Nm · all trims
BatteryAvinox FP700 · 700 Wh · all trims
Travel F/R160/150 mm · all trims
FrameCarbon · all trims
ForkFOX 36 Performance, 160 mm travel, GRIP damper, Sweep/LSR adjustment, 15x110 mm axle, 44 mm offsetFOX 36 Factory, 160 mm travel, GRIP X2 damper, Kashima coating, 15x110 mm axle, 44 mm offset, HSC/LSC/HSR/LSR adjustment
ShockFOX Float X Performance, 210x55 mm, air spring, 2-position lever, LSR adjustment, custom tuneFOX Float X Factory, 210x55 mm, air spring, 2-position lever with LSC & LSR adjust, Kashima coating, custom tune
HeadsetIntegrated 1.5IS, 30.5x41.8x8 mm upper / 40x52x7 mm lower, 45/45 degree bearings, adjustable head-angle cups (5 positions) · all trims
StemAmflow Enduro, 35 mm length, 35 mm clamp · all trims
HandlebarAmflow Enduro Alloy, 800 mm width, 40 mm rise, 35 mm clamp, 5 degree upsweep, 9 degree backsweepAmflow Enduro Carbon, 800 mm width, 40 mm rise, 35 mm clamp, 5 degree upsweep, 9 degree backsweep
GripsAmflow Enduro Grip 2 lock-on grips · all trims
SaddleAmflow Mountain SaddleAmflow Mountain Saddle Titanium
SeatpostAmflow Dropper Post Shim, adjustable travel in 0/5/10/15/20 mm increments (M/L: 190 mm; XL: 210 mm; XXL: 230 mm) · all trims
BrakesMagura Gustav Pro hydraulic disc brake, 4-piston caliper, 203 mm Magura sensor rotors (2.5 mm) front and rear · all trims
Rear derailleurSRAM S1000 Eagle Transmission Derailleur (wireless)SRAM X0 Eagle Transmission Derailleur (wireless)
CrankAvinox SL Crank, ISIS interface (M/L: 155 mm; XL/XXL: 160 mm), 38T SRAM Eagle Transmission DM chainring · all trims
ShiftersSRAM AXS Pod Controller (wireless)SRAM AXS Pod Rocker Controller (wireless)
CassetteSRAM XS-1270 Eagle Transmission 10-52T 12-speedSRAM XS-1295 Eagle Transmission 10-52T 12-speed
ChainSRAM Eagle 70 Transmission Flattop chainSRAM X0 Eagle Transmission Flattop chain
Drivetrain1 x 12 · all trims
Wheels29" front / 27.5" rear, alloy mullet29" front / 27.5" rear, carbon mullet
TyresFront: Schwalbe Magic Mary Radial 29x2.5" Gravity Pro Ultra Soft; Rear: Schwalbe Albert Radial 27.5x2.5" Gravity Pro Addix Soft · all trims
Weight21.4 kg · all trims
Price£6,499£8,999
Rides similarly
Spot a mistake?
