Testing the Shimano XT Di2 Auto Shift – automatic shifting
Automatic shifting, on an emtb, who asked for that? I never found an automatic transmission in a car that shifted the way I wanted. Why would this work on an emtb? Check out my video, or keep reading below.
Well, riding no-hands I forgot about shifting. Coming through corners and into steep hills, never needing to touch the bars. I suddenly realized that was pretty cool. And that’s not the only party-trick, this is the first time I’ve ever shifted while pedaling backwards. That’s not required though. It shifts if you pedal the right way too. Thanks to the Free Shift function, you can coast or pedal, it shifts regardless. As long as you’re not standing still. The motor spins the chain ring slightly to perform the shift.
Auto Shift made riding no-hands very comfortable.
Shimano XT Di2 Linkglide​
Auto Shift is a feature on the updated 11-speed Shimano XT Di2 Linkglide gear system. Linkglide means it's an ebike specific system that has been optimized for shifting under load. I guess you could ride it on a non-assist bike, but you don’t get the automatic shifting. When the ebike battery is depleted, Auto Shift will disengage. But it shifting will still work. There is a buffer of 150 shifts, so I guess it's handy having the shifter after all.
See this video for more info on Linkglide, first introduced on a mechanical gear system.
For the Auto Shift to work, you need either the new EP8 motor (EP801) or the EP6. These motors have new hardware needed for the Auto Shift communication. You do of course need the XT Linkglide Di2 derailleur and the Linkglide cassette too. You might not need the shifter for shifting, but it’s very convenient to have for switching between the Auto Shift modes.
Shifts well​
Shifting under load is improved, which is a necessity. This gear system doesn’t care what you’re doing. Pushing hard in turbo mode, that’s as good a time to shift as any. And it shifts well. Sure, you can hear it. But there are no crunching noises, it doesn’t sound like anything is about to snap. It doesn’t trigger my mechanical sympathy making me ease off the pedals.
Both rider and motor are pushing hard while downshifting.
Shifting isn’t as fast as on the mechanical 12-speed systems, the Linkglide Di2 shifts a bit slower. You don’t notice that when riding in automatic mode. But switch to manual mode and you can notice a slight delay after pressing the shifter lever. The chain will only move off a cassette cog at a certain position, causing the slight delay. This didn't bothered me as I never felt the need to run the manual mode.
Auto Shift settings​
Shimano made two shifting styles, one for pavement and one for trails. A new button on the shifter lets you cycle between A1, A2 and M. The latter is manual shifting mode. You can also set the default gear, my bike was set to 7. This is the gear the bike defaults to when you’re coasting and coming to a stop. I guess I would set it to a lower gear when riding demanding trails. 4th gear could be better when stopping before a climb.
There's a new button on the shifter, just below the XT letters. This cycles through Manual and Auto modes.
There's a new button on the shifter, just below the "XT" letters. This cycles through Manual and Auto modes.
The bike will shift up and down depending on your cadence. But when you’re not pedaling it will calculate which gear you need to be in depending on your speed. This means the bike will shift gears while coasting, and it can be shifting quite a lot as your speed changes while coasting. This ensures you’ve got the right gear when you start pedaling again.
Auto Shift settings in the E-Tube app
A1, the first Auto Shift preset was set to the MTB style and it was set to maintain a cadence of (+/-) 72, which worked well. I also tried setting cadence to 71. It didn’t make a lot of difference of course, but I liked it, it was a bit more eager to shift. A2 was set to Pavement and it was less eager to shift, it’s a bit too sticky for the trails. Another option is setting both presets to MTB and having one mode for chill trails and one for more agressive riding.
Cadence level can be changed on the display. Using the app you can set the riding surface, default gear, cadence and shift sensitivity. We only tried making minor changes to the recommended settings.
The display shows we're riding Auto Mode 1 and we're in 5th gear.
Impressions​
There were a few occasions where I was waiting for the bike to shift, but I never had to interfere and push the shifter. That could be annoying on a road bike I guess. But it’s not like I’m always in the perfect gear when riding an emtb. When riding mechanical shifting, I can find myself in a steep hill in the wrong gear. Then I’ll avoid shifting and have the motor help me up. With the improved shifting, Auto Shift doesn’t need to worry about drivetrain failure. The shifter can be used to force shifting in automatic mode too.
If you race emtbs, this might not be the ideal drivetrain. It can take a bit of time getting in the optimal gear in some situations. Shimano is working to make the system more suited for racing though. They’ve got factory racers riding the Di2 Linkglide and experimenting with different softwares.
A Bulls emtb with the EP6 motor and Di2 Linkglide.
Photo: Irmo Keizer
Cheaper Di2?​
I'm not sure about the prices as I only received prices in Norwegian. But bike-components.de lists the SW-M8150-R shifter at €165 ex. VAT. The RD-M8150 deraileur is more than double that. Bike-components.de lists the CS-LG700 cassette at €125 and the CS-LG400 at €95 ex. VAT. Both are 11-speed 11-50t. And you need a Linkglide specific chain too
The Linkglide XT Di2 isn’t a cheap option. And we won’t see Deore or SLX Di2 as those groups have been discontinued. But there is the new cheaper Cues group set that includes electronic shifting, the U6050 for 10-speed and 6070 for 11-speed.
Photo: Irmo Keizer
Photo: Irmo Keizer
Photo: Irmo Keizer
There’s one problem though, it doesn’t come with a clutch, the chain tension mechanism that reduces chain slap. I’m having a hard time wrapping my head around that fact. Shimano removed the Deore and SLX group sets, and they’re not replacing them? XT is the new entry level eMTB drivetrain? We need the Cues Di2 Linkglide system with a clutch.
Conclusion​
I didn't really liked automatic transmission in cars, I never had that experience with the Auto Shift. I did an entire ride not wanting to use the shifter. I never missed doing the shifting. Moving your thumb slightly to press a lever is hardly any work, but now it feels a bit pointless. I would happily ride this on my next bike.
Foto: Dan Milner
Foto: Dan Milner
Having a chat with Henry
About author
knut7
Started mountainbiking in the 90s. Moved to emtbs in 2014 and have been reviewing them since 2016. Contact me here https://emtb.no/contact/
Comments
Nice article and video.
What would you choose if you had infinite cash and could get either SRAM Transmission or the new Shimano drivetrain, and why?
I haven't ridden the Transmission yet, but I'm intrigued by that design. Having the rear axle taking all the load from the deraileur and ditching the RDH seems great. I enjoyed riding the Auto Shift, and I would happily ride that on my next bike to get to know it even better.
I would like a mix of both, Auto Shift and no RDH :) The 12 speed mechanical systems can be very sensitive to any misalignment of the RDH, leading to reduced shifting performance. But, if the new Di2 Linkglide is less sensitive in that regard, it becomes less important having a rear mech without an RDH.
Has this person even driven since 1989?
Surely they can use cadence and torque sensor to shift off power? If your on full torque through your legs the last thing you want is it changing gear. ?
I’ve noticed by messing with walk mode and changing gears , that it’s very dependant on the wheel speed sensor in deciding what it’s doing. So if its shifts are dependant on wheel speed signal that would explain it, and why it’s doing such a stupid thing at the worst time.
I was expecting it to change when cadence and or torque drops after peak. Disappointing tbh
I´m curious to know why they only added auto shift on the 11sp Linkglide and not the 12sp Hyperglide?
You guys think they might release a firmware update in the future adding auto shift to 12sp?
The Shimano way is to be as little backwards compatible as possible.
But this is not about backwards compatibility as the new "rd-m8150-11" and "rd-m8150-12" were released simultaneously.
I´m thinking it might be something mechanically that made them have to skip autoshift for the 12 speed.
Autoshift has to be able to shift under heavy load. The Linkglide is designed to handle this and it will only shift at certain points on the cassette. The 12-speed DI2 systems have Hyperglide+ chains/cogs. HG+ will shift much faster but it isn't designed to handle the same kind of load while shifting.
