TrekMichael
Riding a Trek Rail 9.9 with Rockshox Zeb Ultimate fork. When I set the pressure to the recommended pressure I don’t even get 20% sag. Anyone have any experience with this? I weigh 82kg and the recommended pressure is 80psi
Did you do this procedure?Riding a Trek Rail 9.9 with Rockshox Zeb Ultimate fork. When I set the pressure to the recommended pressure I don’t even get 20% sag. Anyone have any experience with this? I weigh 82kg and the recommended pressure is 80psi
Let all the air out and burp the seals with the smooth side smooth the zip tie against the seal until the forks are sitting on the tire. then pump them up again and you should get the sag. But after riding the air will build up in the lowers again and the only way to get the sag is less psi in the fork. This appears to be normal with bigger stanction forks.The 2023 ZEB has bleeders on them but for now the zip tie seems to work.Riding a Trek Rail 9.9 with Rockshox Zeb Ultimate fork. When I set the pressure to the recommended pressure I don’t even get 20% sag. Anyone have any experience with this? I weigh 82kg and the recommended pressure is 80psi
