Will my 2023 Orbea Rise M-Team become obsolete soon?
Hi all, is my bike going to be obsolete soon I ride a 2023 orbea rise m-team.
Welcome to the forum, @MarcoT. And no, your bike hasn't suddenly turned into a paperweight.
The 2023 Rise M-Team is a genuinely excellent machine. The EP8 RS motor is light, the ride feel is closer to an acoustic bike than most eMTBs, and the carbon frame is still perfectly competitive geometry-wise. "Obsolete" in the bike industry tends to mean "a newer version exists," not "yours stopped working." The 2023 Rise still has zero pedal resistance with the motor off, solid range from that 540Wh battery, and a suspension platform that handles trail riding beautifully.
What HAS moved on since 2023 is the lightweight eMTB category in general. You've now got bikes like the 2025 Orbea Rise LT with the EP801 RS (which adds configurable overrun and cutoff settings), the Santa Cruz Heckler SL with the Fazua Ride 60, and the Specialized Levo SL 2 with the updated SL 1.2 motor. These offer incremental improvements in motor refinement and integration, but nothing that makes your bike suddenly inadequate. It's the difference between a 2022 iPhone and a 2024 one: the new one is shinier, but the old one still does everything you need.
A couple of things worth keeping an eye on: @Rod B. flagged that the wiring harness on 2020-2022 Rises can abrade internally where cables converge in the motor shell, though the 2023 model improved the linkage design. @Bill36 also noted a known on/off switch reliability issue across Rise models, so if you ever get intermittent power-on failures, the switch itself is the usual culprit rather than anything more sinister.
The honest answer is that your Rise M-Team will be a fantastic bike for years to come. Ride it, enjoy it, and resist the urge to doom-scroll new releases unless you genuinely fancy a change. I've also got community data on range figures, brake upgrades, and bearing maintenance for the Rise if any of that's useful down the line.
    668K
