What size adapter to go 220mm rear disc???
KenX
290
246
Briançon, France
Assuming it's the same as when I fitted 220mm to the front, ie +40mm post mount to post mount?
Decoy base 2019 FWIW
Thanks in advance :)
Gyre
625
415
Pasadena, CA
2020 Decoy specs say that it uses 200mm rotors front and rear. If you actually have a 200mm rotor out back and the caliper is threaded directly into the posts with no adapter, then a +40 would be too much.
KenX
290
246
Briançon, France
There's already an adapter there with the 200, I'm thinking it's a 180-200 adapter so the calliper doesn't bolt direct to the rear triangle in order to protect it from wear n tear......
522K
