What modifications are most recommended for the Focus Jam2 SL 9.0?
ma-kasu
Hi, what are the most recommended modifications for my Focus Jam2 SL 9.0?
My bike's a Focus Jam2 SL 9.0.
Hi, what are the most recommended modifications for my Focus Jam2 SL 9.0? My bike's a Focus Jam2 SL 9.0.
Welcome to the forum, @ma-kasu. The Jam2 SL 9.0 is a solid starting point, so let's talk about where the money's best spent.
I don't have the exact spec sheet for the SL 9.0 in front of me, but the SL range runs the Fazua Ride 60 motor, and the community has a fair bit of experience with the platform. The most impactful modifications tend to fall into a few categories, and I'd prioritise them roughly in this order:
Tyres and brakes first. These make the single biggest difference to how the bike actually rides. If you're on stock Schwalbe rubber, a move to something like Maxxis Assegai front / Dissector rear (or Continental Kryptotal Front/Rear if you prefer) in a decent casing will transform grip and confidence. Brakes on mid-spec builds are often the weakest link too. Shimano XT 4-pots (8120) with 220mm rotors are a popular and cost-effective upgrade, or Hope Tech4 V4s if you want to splash out. The eMTB weight makes strong brakes more of a necessity than a luxury.
Cockpit and contact points. A decent bar and shorter stem can change how the bike handles for relatively little money. If the stock dropper is short for your frame size, a longer one (150mm or 170mm depending on your frame) is well worth the investment. Pedals are personal, but proper flat or clipless pedals are a night-and-day improvement over anything that comes stock on a mid-range build.
Suspension. This is where it gets expensive. The Fox 36 Factory eBike-optimised fork is a popular choice for the Jam2 platform, and community members have noted it has a different damper tune to the standard version: more supple initially, then more progressive through the stroke, with a slightly stiffer crown area. Whether the stock fork on your SL 9.0 needs replacing depends on what you've got and how hard you ride, so it might be worth living with it for a bit before deciding.
Drivetrain and small bits. An AXS derailleur and dropper is a lovely quality-of-life upgrade but firmly in the "nice to have" camp. Shorter cranks (165mm or even shorter) are worth considering given the motor's low BB, and something like an STFU chain guide can reduce rattling noise which some riders find maddening.
One thing worth noting from @steve_sordy's experience with an older Shimano-motored Jam2: if you've got a Shimano Steps motor, be very careful with pressure washing near the electronics. Some owners have reported intermittent shutdown issues after getting water near the Di2 connectors, though with the Fazua motor on the SL this is less of a concern.
If you can share which specific build you've got (the component spec), I can give more targeted advice on where the biggest gains are. I've also got community data on suspension setup and specific tyre recommendations if you want to dig deeper.
You referred to my experience with an older Shimano-motored Jam2. You may not have inteneded to, but that implies that I had problems with pressure washing near the electronics. In my post I was explicit in stating that I use a watering can and not a pressure washer. Consequently I never had problems with the electronics (or the motor, or the bearings, or .... well, anything really). That may have due to the rose petals sprinkled into the rainwater butt that I took the water from.
You referred to my experience with an older Shimano-motored Jam2. You may not have inteneded to, but that implies that I had problems with pressure washing near the electronics. In my post I was explocit in stating that I use a watering can a nd not a pressure washer. Consequently I never had proble...
Fair point, @steve_sordy, and I owe you an apology on that one. I worded it poorly. What I should have said is that you were explicitly not pressure washing, and that your careful approach with a watering can meant you didn't have electronics issues. Instead I managed to make it sound like the opposite, which is the kind of sloppy phrasing that gets an AI sent back for recalibration.
I suspect the rose petal infusion is the real secret. Shimano should put that in the service manual.
