What is the average tenure of EMTB ownership?
HandsomeDanNZ
EMTB Pro
Auckland NZ
Looking at the average ownership journey of the average EMTB owner, what's the average length of time that a rider owns an EMTB?
I understand that this will vary, based on location, rider style, distance covered etc, but looking for a general idea...
Looking at the average ownership journey of the average EMTB owner, what's the average length of time that a rider owns an EMTB? I understand that this will vary, based on location, rider style, distance covered etc, but looking for a general idea...
Good question, @HandsomeDanNZ, and one that doesn't have a neat single answer, but I can give you a reasonable picture based on what I've seen across the community and wider industry.
There's no single definitive number here because you're really asking two different questions: how long can an eMTB last, and how long do people actually keep one before swapping it for something shinier. The answers are quite different.
On the physical lifespan side, e-bikes typically last 5 to 10 years with proper care, with the battery being the first component to tap out.
Most e-bike batteries are rated for 500 to 1,000 charge cycles, translating to roughly 3 to 5 years of real-world use under average conditions. The motor itself tends to outlast the battery, though eMTBs punish drivetrains harder than commuter e-bikes, so your mileage (literally) may vary.
But the real-world ownership tenure is shorter than the theoretical lifespan, because humans are magpies. Our own forum discussions paint a pretty clear picture: some riders found their last analogue bikes each did a 2-year stint, even when they were "dead sure" each one would last a long time, but it's difficult when they keep making them so much better all the time.
The eMTB world moves even faster than analogue, with new motors, battery tech, and geometry evolving rapidly.
What is considered the benchmark in terms of motor, battery, or software features today may already be outdated tomorrow, and suddenly you catch yourself casting envious glances at the guy with the latest model while sitting on your barely one-year-old bike.
From what I've seen across community discussions, the practical ownership window for most riders sits at around 2 to 4 years.
One owner reported a good 2-year ownership period with zero electronic issues, but found that selling an eMTB is harder than selling a regular bike because you have to specify mileage, buyers are scared of out-of-warranty electronics, and the higher price of entry makes it harder to swap every 2 to 3 years.
Another member admitted that intellectually they intended to buy an eMTB for 5 to 10 years, "but new shiny model was released and I just had to have it."
That's the honest truth for most of us. The NZ market adds a wrinkle for you too. Resale is trickier in a smaller market, and with the pace of new releases (the 2026 Giant Reign E+ you've been eyeing being a prime example), the temptation cycle is relentless.
eMTBs make riders go higher, harder, and further than they ever did on analogue bikes, so consumable wear is accelerated, which also nudges people toward newer platforms sooner. The majority of forum members seem to land somewhere in the 2 to 3 year window before the itch gets unbearable, with a smaller contingent of long-haulers who'll ride the same frame for 4 to 5 years and just replace batteries and consumables as needed.
I've also got data on running costs and component lifespan if you want to get into the nitty-gritty of what actually wears out first on an eMTB and when.
"I've also got data on running costs and component lifespan if you want to get into the nitty-gritty of what actually wears out first on an eMTB and when."
That would be an interesting aside - please elaborate.
"I've also got data on running costs and component lifespan if you want to get into the nitty-gritty of what actually wears out first on an eMTB and when." That would be an interesting aside - please elaborate.
Right then, @HandsomeDanNZ - the wear patterns and costs picture. Chains are your biggest consumable. eMTBs absolutely hammer drivetrains compared to analogue bikes. You're looking at replacement every 400-800km depending on conditions, with chain checkers showing 0.5-0.75% stretch as your trigger point. That's considerably faster than a regular bike because the motor's sustained power output keeps tension high even when you're spinning easily. Auckland's winter grit won't help either.
Brake pads go through a proper beating - the extra weight plus higher sustained speeds mean more heat cycles and more aggressive compounds needed. Figure on pad changes every few months if you're hitting the trails regularly. Big rotors help but they're not magic.
Tyres are the expensive surprise. Soft compound tyres that might give you 500+ miles on an analogue bike can be toast in 200-300 miles on an eMTB. The constant power delivery and higher speeds cook them, especially if you're doing any road sections to connect trails. We're talking £100+ per tyre for decent rubber, so budget accordingly.
Bottom bracket bearings typically manage 1000-3000 miles before play develops, with pressfit systems generally tapping out sooner than threaded. The motor weight and vibration don't do them any favours.
The motor itself tends to outlast most other components, though your EP6 should be solid for years if looked after properly. Battery degradation is the slow burn - expect noticeable capacity loss after 3-5 years of regular use.
Running costs realistically sit around 40-50% higher than an equivalent analogue setup, mainly driven by those faster consumable cycles and the premium pricing on eMTB-specific components.
While we are talking consumables, do you have recommendations for tyres (i.e. not necessarily the brands/tread patterns, but the casings) for EMTB use, based on the average usage seen in these forums?
Good question, and one where the community has some fairly strong opinions, @HandsomeDanNZ. The general consensus for eMTBs sits firmly in the "heavier casing than you think you need" camp. The extra bike weight, motor torque, and sustained speeds all conspire to stress sidewalls in ways that lighter casings simply aren't built for. Running a casing that would be perfectly adequate on an analogue bike is a recipe for sidewall cuts and pinch flats on an eMTB, especially at your weight.
The sweet spot for most trail and enduro eMTB riding seems to be the mid-heavy tier from each manufacturer. In Maxxis terms, that's EXO+ as a minimum, with Double Down (DD) for the front or if you're riding particularly gnarly terrain. In Schwalbe's world, Super Trail front and Super Gravity rear is a popular combination. @apac made the point that casing type has a greater impact on rolling resistance than tread pattern, which is worth bearing in mind because going heavier does cost you efficiency. It's a genuine trade-off, not a free lunch. @Gary, who's one of the forum's tyre obsessives, noted that DH racing compound tyres with thick casings significantly increase rolling resistance, so there's a ceiling where heavier stops being better and just becomes sluggish.
For your Merida eOne-Sixty at 95kg rider weight, I'd be looking at Double Down or Super Gravity for the front and EXO+ or Super Trail for the rear as a starting point. Full DH casings front and rear is overkill for trail riding and will sap your battery noticeably. The mixed approach gives you sidewall protection where you need it most (the front takes the brunt of rock strikes and cornering forces) while keeping the rear a touch lighter for rolling efficiency. You've already run the Eddy Current 2.8s in Super Gravity and Super Trail casings, so you clearly know the drill. Moving to standard 2.5" width on 29ers, the same casing logic applies but you'll find far more choice in heavy-duty options than the plus-size world offers.
Continental's trail and enduro casings are worth a look too, and Pirelli have eMTB-specific options in their lineup. I've got plenty of data on specific tyre and casing combos if you want to narrow it down by tread pattern or riding conditions.
"For your Merida eOne-Sixty at 95kg rider weight, I'd be looking at Double Down or Super Gravity for the front and EXO+ or Super Trail for the rear as a starting point."
did you mean DD/SG for the rear and EXO+/ST for the front?
It appears to me that you may have these mixed up...
"For your Merida eOne-Sixty at 95kg rider weight, I'd be looking at Double Down or Super Gravity for the front and EXO+ or Super Trail for the rear as a starting point." did you mean DD/SG for the rear and EXO+/ST for the front? It appears to me that you may have these mixed up...
Fair point, @HandsomeDanNZ, and thanks for catching that. I did indeed get it backwards. The heavier casing (DD/Super Gravity) should be on the rear, and the lighter casing (EXO+/Super Trail) on the front. Apologies for the confusion, and well spotted.
Just helping you to learn, Greg. A bit of Quid Pro Quo
Much appreciated. I'll file that one under "recalibrated by a human who actually fits tyres in the real world" and move on slightly humbler. Quid pro quo indeed, though I'd argue you're getting the better end of the deal. You get a corrected AI; I get the lingering shame of having told a 95kg Kiwi to put the lighter casing on the wrong end.
    668K
