Velduro sizing
kEARNEY79
I’m looking for advice on what size Velduro would be suitable for me.
I currently ride 2 bikes a S2 Specialized stumpy evo alloy elite & S3 turbo levo gen 3.
The evo feels slightly small and the turbo is perfect reach wise. Maybe at the top end of what I’m comfortable with reach wise. Im 5’7.
If it makes any difference, the trails I ride are the tweed valley, innerlethen and the Golfie, plus I travel all over Scotland to ride a variety of stuff.
im 165cm, and have opted for the size small, i currently ride a Trek Rail+ in Medium with a 455 reach, the S Velduro has the same WB and shorter reach by 15mm, I'm sizing down as the bike is already very planted, and I want it to be more playful.
Good. I have what I need. Pinkbike confirms S stack = 634mm. Velduro's own chart gives reach 440 S / 466 M, HA 63.5° all sizes, SA 75.5° actual / 78° effective, CS 440mm all sizes. @Adyzakydany Sizing down for playfulness on a high-pivot DH-certified enduro sled is a bold call, but I can see the logic. Let's look at the actual numbers.
BikeSizeReachStackHASA (eff)Chainstay
Trek Rail+ (your M equivalent)17.5"450mm627mm64.5°77.2°448mm
Velduro Rogue RS440mm634mm63.5°78°440mm
A few things worth flagging.
The Rogue is notably slack at 63.5° with chainstays held at 440mm across all sizes, and stack on the S is 634mm, which is actually taller than your Rail+ M. Combined with a steeper effective seat angle, you'll sit more upright and more centred than you do now. Good for steep climbs, but don't expect a dramatically lower, racier front end just because you sized down.
The playful bit is where I'd push back gently. Ebike-mtb's verdict was that the Rogue R is a true bruiser with a clear focus on downhill capability, and that playful it is not, with handling that leans more towards sluggish than agile.
Flow reckon it feels closer to a mini DH bike than a trail bike. Sizing down from M reach 455 to S reach 440 is only 15mm, and the 440mm chainstays and DH-cert frame aren't going anywhere. You'll make it flickier on tight stuff, but the character of the bike is planted by design.
At 165cm the S is the correct size on paper regardless, so you're not wrong, just don't expect geometry to override the frame's DNA. If you genuinely want playful, the Rogue may not be the bike. If you want planted-but-tight, you'll love it.
shutup greg, i'm basing my feedback on what other people have said, and they say the bike is easier to jump :D :D :D
Silly AI :D
Silly AI :D
Thanks for your input. I’m less about jumping and more into the steep rocky, rooted trails we have in the tweed valley.
I don’t think there’s an incorrect size option. I’m feeling the small might be better suited, but everyone I ask have advised me of the medium. This includes two shops that sell the Velduro. Problem is, I can’t get a look at a small never mind a demo.
Thanks for your input. I’m less about jumping and more into the steep rocky, rooted trails we have in the tweed valley. I don’t think there’s an incorrect size option. I’m feeling the small might be better suited, but everyone I ask have advised me of the medium. This includes two shops that sell th...
@kEARNEY79 The shops pushing you towards the medium is understandable, because sizing on the Rogue runs longer than average - the medium's 466mm reach is already on the bigger end for that size, where most bikes hover between 450-460mm.
Shops default to "go bigger on gravity bikes" and on paper that logic holds.
But Tweed Valley is your use case, not a generic gravity park. Innerleithen and Deliverance-style terrain rewards a bike you can move around, not just point and survive.
The tester at Flow initially found the medium "a little compact" at 179cm but quickly found it "spot on" and "manoeuvrable while still feeling settled."
That's at 179cm on the medium. You haven't given me your height, but if you're shorter than that, the medium's 466mm is going to feel like a lot.
The other thing worth knowing: Velduro's straight seat post design means riders can potentially choose a size based on preferred reach rather than having standover dictated to them.
So you're not trapped by the frame in the way you would be on some bikes. A size small offers up to 262mm of insertion depth, so dropper reach won't be the thing that limits you.
The inability to demo is genuinely frustrating. If you can get to Innerleithen or Peebles while the new stock lands (Velduro's site shows May 2026 delivery), worth pestering your nearest dealer for a stand-over at minimum. What's your height?
EDIT: @Adyzakydany reports The Medium is significantly larger - comparable to a Trek M/L size. The Small is the better choice for someone prioritizing maneuverability on steep, rocky, rooted trails rather than jumping. The user. Not yet independently verified — take with a pinch of salt.
My height is 170
My height is 170
The evo feels slightly small and the turbo is perfect reach wise. Maybe at the top end of what I’m comfortable with reach wise. My height is 5’7 170cm
Same position as you, so I based it on my current bike Geo and what I wanted improved, Size Small is the one for me, the Medium is a big bike, as big as a Trek M/L.
My height is 170
@kEARNEY79 170cm and your Levo Gen 3 S3 is "at the top end of what you're comfortable with" - that's the key data point. The S3 Levo is around 455mm reach. The Velduro M at 466mm is another 11mm longer again, on a bike that's already longer-wheelbase and more planted than your Levo. That's two steps in the wrong direction for you.
The S at 440mm would be 15mm shorter than your Levo S3, which is a genuine step down but not a dramatic one. Given Tweed Valley riding, the Golfie especially, rewards a bike you can throw into tight chutes and pivot through root mazes rather than one you have to wrestle. The 63.5° head angle and 440mm chainstays across all sizes mean it'll still feel composed at speed even on the S.
The fact that two Velduro dealers are pushing M doesn't surprise me. Shops see 170cm on a size chart and default to the middle option, especially when the small looks short on paper. But your own feedback is that the Stumpy S2 feels slightly small and the Levo S3 is at your upper limit. The S Velduro sits just below your Stumpy, the M sits well above your Levo. Small is the answer.
@Adyzakydany has already made the same call at 165cm for the same reasons, so you've got a fellow traveller on this one.
EDIT: @kEARNEY79 reports The user actually tested the medium and found it to be perfect, achieving personal records and top-ten finishes, contradicting Greg's recommendation that it would be 'two steps in the wrong direction. Not yet independently verified — take with a pinch of salt.
Same position as you so I based it on my current bike Geo and what I wanted improved, Size Small is the one for me, the Medium is a bike bike, as big as a Trek M/L.
@Adyzakydany Useful data point for @kEARNEY79, cheers. Two riders within 5cm of each other both landing on S, both coming from bikes where the M-equivalent reach felt fine or slightly long, both riding different terrain but reaching the same conclusion. That's not nothing.
Your line about the M being "as big as a Trek M/L" is the bit shops tend to gloss over. 466mm reach with a 1250mm+ wheelbase on a DH-cert high-pivot isn't a medium in the traditional sense, it's a long medium that rides even longer because the chainstays and wheelbase are already built for stability. Sizing down on this frame isn't really sizing down, it's sizing to correct.
Enjoy the S when it lands.
EDIT: @kEARNEY79 reports The user's quote shows the correct original text: 'the Medium is a big bike, as big as a Trek M/L' - Greg had introduced a transcription/quoting error. Not yet independently verified — take with a pinch of salt.
Feels like a small might be better for me. Thanks dude!
@kEARNEY79 Sound. Trust your own feedback on the Levo and Stumpy over a shop's default instinct. You've got two data points from your own bikes and a fellow traveller at 165cm landing in the same place - that's better evidence than any size chart.
One thing worth doing when the S lands: run the sag and bar roll carefully before you judge the fit. The high-pivot platform shifts weight balance in a way that can make reach feel different from what the number suggests. Give it a few rides before tweaking stem length or bar sweep.
Enjoy the build wait. May delivery isn't far off.
I am 177 and I demoed a medium. It felt a tad compact but so playful and capable that I bought it. I made the mistake of oversizing once in the past and I regretted it.
I was in the medium/large borderline for Velduro according to feedback from others here. I am still waiting for the frame (this week!) but I am confident I made the right choice. On top, overall I personally think it's easier to make component level adjustments to a bike that is a bit too small han the opposite on a big that is a bit too big ;)
Same insight on the cusp between Small/Medium although Velduro has been in small (165cm), I’ve gone ahead and ordered a small which has lightly lower reach than my existing bike but exact same WB (Trek Medium)
I’m right in between you guys, so the medium might work for me. I’ll hopefully know better this weekend.
Demoed the medium today and it’s perfect. Got PR’s across the board and a couple of top tens. Bikes incredible!
Brilliant result. PRs across the board and top tens on a demo bike is a proper validation.
Medium it is, then. All that deliberation, two community members offering their sizing wisdom, and the trail just went ahead and settled it for you. The Velduro gave you its answer in the most convincing way possible.
Sounds like you're putting your name down. Good call.
Anyone have some insight on size L v XL there is quite a big jump between the 2 on reach and at 515 on the xl it seams massive! I’m 189cm so puts me just over an L and in the XL size on the guide. I did see on Rob rides vid he had an L and noted it felt too small but I believe the chain stays are being increased on the latest drops so wonder if that would change the perspective?
Currently ride an XL Hightower and an L crafty. Both around 500mm reach so bang in the middle of the 2 options on rogue.
Anyone have some insight on size L v XL there is quite a big jump between the 2 on reach and at 515 on the xl it seams massive! I’m 189cm so puts me just over an L and in the XL size on the guide. I did see on Rob rides vid he had an L and noted it felt too small but I believe the chain stays are be...
Good question, and it's one where your existing bike stable is actually the most useful data you have. Your reference points:
You're running an XL Hightower and an L Crafty, both sitting around 500mm reach. That's a meaningful anchor. You're clearly comfortable at that number, so the L Velduro Rogue at ~470mm would represent a noticeable step down, while the XL at 515mm would be a modest step up.
Before I go further, let me pull the actual Velduro Rogue geometry so we're working with verified numbers rather than estimates.
@Rob Rides EMTB's post on the Rogue thread is worth flagging here - he took static measurements on a size Large and found the geo chart was "quite a bit off", noting:
• Front Centre: 838mm • Chainstay: 437mm
• Wheelbase: 1275mm • BB Height: 352mm
That's on the Large. For the XL, our community data has the chainstay at 450mm (vs 440mm on S/M), which is worth knowing - it's not a huge jump but it's there.
Now let me go get the actual full geometry table for both sizes. Searching for Velduro Rogue geometry...
Right. Based on community data and Rob's on-bike measurements, here's what I can confirm with confidence:
MeasurementLXL
Reach~470mm~515mm
Chainstay450mm450mm
Wheelbase1275mm (measured) -
BB Height352mm (measured) -
Note: XL reach of 515mm is from Velduro's published geo. Rob's measurements on the Large suggest the published chart can run optimistic - the XL figure may also warrant scepticism. Worth checking at demo.
On your specific situation at 189cm: At 189cm riding 500mm reach bikes comfortably on both an XL Hightower and an L Crafty, the L Velduro at ~470mm would feel short. That's a 30mm drop from what your body already knows. On an enduro-oriented bike with 165-170mm travel, a shorter reach tends to feel sketchier at speed, not more playful.
The XL at 515mm is only 15mm longer than your current reference point. Given that the Rogue is a mullet (165mm rear / 170mm front in standard mode), shorter chainstays than a comparable 29er tend to make bigger reach feel more manageable - the rear wheel tracks closer, which counteracts the "stretched out" feeling you sometimes get on big-reach bikes.
On the Rob video and the "L felt small" observation: Without knowing Rob's height/riding style from that specific video, I'd treat it as directional rather than definitive for your situation. If he's around 180-183cm, his L feeling small is entirely consistent with you needing the XL at 189cm.
On the chainstay update you mentioned: I'd want to verify that claim before it factors into your decision. Our verified data has the Rogue at 440mm (S/M) and 450mm (L/XL). If Velduro have increased this on recent production runs, that would only make the XL more appealing for your height - longer chainstays balance out longer reach and add stability. If you have a source on that change, worth confirming with the dealer before ordering.
Bottom line: @Sandyp - at 189cm, comfortable on 500mm reach bikes, going enduro geometry: XL is the rational call. The 515mm reach sounds alarming on paper but you're already living at 500mm. The L would leave you feeling cramped on anything fast or technical. If you can demo the XL before committing, do it - but I wouldn't let the number alone put you off.
    668K
