Review Vaude Bike Gaiter Long
Doomanic
🛠️Wrecker🛠️
8,478
9,957
Product Image:
Product name: Vaude Bike Gaiter Long
Price paid: £25.00
Score (out of 10): 8
Review: @Kiwi in Wales wouldn't shut up about these ( :p ) so I decided I'd give them a try and I'm very glad I did.
I've ridden in them twice now, the first time in a typical FoD slopfest and the second on a claggy mud ride. Both times I've finished with warm, dry feet. So they work. (y)
They are made of a thin water and wind repellent breathable material. I'm not sure how breathable they are, but I do get a bit sweaty under them. I'm also not sure how durable they'll prove to be in a crash, but if anyone can test that out, it's me. :D
I got them from Amazon (sorry :( ) and bought 2 sizes as I wear a 46 shoe and the sizes are 44-46 and 47-49 and FiveTens are quite bulky. As it turned out, the 44-46 were pretty much spot on with no excess material flapping around at the toe and the Velcro fastening at the back fitting securely. There are adjuster straps over the toe and at the front of the ankle to take up any slack in the material.
The only niggle for me is the fastening at the back, on one side it's a full run of Velcro but the other side is pads with gaps in between. This my not be an issue, but I won't know until I've ridden in some proper English rain.
Here's a pic of my shoe after today's clagfest; as you can see, some mud has been forced up between the show and the gaiter but overall the shoe is clean and dry.
Stumpy
Staff member
641
622
Essex, UK
I got some after @Kiwi in Wales recommendation and can vouch for them too. Nothing like warm dry feet (or in my case foot ?) when the rest of you is covered in mud....
Doomanic
🛠️Wrecker🛠️
8,478
9,957
An update. The gaps in the velcro do let in water if you ride through deep puddles and the splash hits them just right but my shoes are still far less wet than they'd be without the gaiters.
JCB
24
24
Burnie, Tasmania
I have never seen those before, but I am keen to try them out.
Similar concept to Endura flat pedal over shoe that I was considering, but those ones looks proper...
Any more photos of them on your rides ?
Also which pants do you use with them ?
Doomanic
🛠️Wrecker🛠️
8,478
9,957
No recent pics, sorry.
I either wear them with shorts and kneepads or ex-MOD Gore-Tex trousers, depending on weather conditions on the day. The gaiters are long enough that they are over the neoprene kneepads.
Kiwi in Wales
Short cranks rule!🏴󠁧󠁢󠁷󠁬󠁳󠁿
1,240
1,588
Carmarthen, Wales
Dom is 100% correct. The gaps in the velcro at the back will sometimes let water in if you ride through deep puddles depending on your foot or leg position.
However, if you or someone in your family is familiar with a sewing machine. It will take 15 minutes and a few £’s worth of Velcro to add the following fix. A sewing shop will do the same for a fair price as well I presume ;)
Just so you know, the gaiters below are well over a year old and have worn really well considering I use flats with long pins.
Before
After
20,488
You should send that fix to Vaude in exchange for a new pair. It uses the same amount of velcro as they use now and is easier to manufacture with a single wide strip running top to bottom as opposed to 4 sideways strips.
neils
201
114
Wokingham UK
Mine arrived yesterday. Looking forward to trying them out with my FiveTen.
Don’t think I’ll need them with the Northwave Himalaya boot when it comes back from LSR from being converted with FiveTen Stealth Rubber. They’re waterproof and combined with my Endura MT500 trousers I should be able to just hose them down whilst doing the bike.
522K
