Turning an Enduro Mountain Bike into an E-Bike: Pros and Cons
GiGaX73
Gorizia
Hi Greg, an Italian friend of mine wants to buy a used enduro mountain bike for about €500 (considering the local used market), preferably a 29er, and then convert it with an electric conversion kit.
The modification must comply with Italian regulations regarding power output, maximum speed, and the absence of a manual throttle. It must also take into account upgrading the braking system and other components to handle the additional weight.
In your opinion, which mechanical parts would need to be modified? What would be the estimated total cost of the entire operation?
Based on your assessment, would it make economic sense, or would it be better to look for a used e-bike at that price?
Hi Greg, an Italian friend of mine wants to buy a used enduro mountain bike for about €500 (considering the local used market), preferably a 29er, and then convert it with an electric conversion kit. The modification must comply with Italian regulations regarding power output, maximum speed, and the...
@GiGaX73 Your mate's got an interesting project on his hands, but the economics are brutal I'm afraid.
For Italian compliance, he'll need a mid-drive kit staying under 250W nominal with 25km/h cutoff - probably looking at a Bafang BBS02B or similar around €400-600. Then factor in a decent battery (another €300-400), controller, display, wiring, and installation. That's already €800-1000 before touching the bike itself.
Now the mechanical upgrades: those are the real wallet-killers. The drivetrain will need serious reinforcement - chain, cassette, derailleur, and likely the freehub won't cope with motor torque for long. Brakes absolutely must be upgraded to at least 4-piston hydraulics front and rear, probably €200-300 for decent stoppers. The frame and wheel bearings will take a hammering from the extra 8-10kg, so budget for more frequent replacements.
Bottom line: €500 bike + €1200-1500 conversion = €1700-2000 total, and you'll have a frankenbike that's heavier, less refined, and potentially less reliable than purpose-built eMTBs.
For that money, he could find a decent used eMTB from 2021-2022 - maybe a Cube Reaction Hybrid or similar that's already sorted with proper brakes, reinforced frame, and warranty coverage. The used eMTB market has some proper bargains now that early adopters are upgrading.
Conversion kits have their place, but starting with a €500 donor bike isn't it.
    668K
