Rail (625Wh) Trek Rail Parts Diagram - Aluminium
Hamina
493
391
FIN
Here's all the numbers in table format. Much easier to copy paste and search from the net. Message me any updates.
ItemDescriptionPart NumberQtyNote
1Knockblock Chip5367231
2M4x16mm BoltW5327633Torque 3Nm
3“Control Freak” GuideW5192322
4Housing Clamp5800672
5M4x9mm Bolt5800672
6Integrated Speed SensorW5822441
6Integrated Sensor MagnetW5626061
6Mainframe1
7Rocker Link1
8Seatstay1
9Chainstay1
10Downtube Bumpers5565492
11Chainstay GuardW5875941
12Thru Axle, Boost 148W5834691Torque 10Nm
184.5mm Length
M12x1.0x15.5mm Threading
Kit 599911
1323mm ABP NutW5834201Torque 15NmKit 599911
14Axle GuideW5834191Kit 599911
15Derailleur HangerW5834231Torque 15NmKit 599911
16ABP BearingW5834242Kit 599911
17Mino Link BoltW5792962Torque 17Nm
18Rocker:Seatstay BearingW5292242
19Upper Shock SpacerW5299692
20Mino Link NutW5292232
21Rocker AxleW5354691Torque 22NmKit 599910
22Rocker Axle SpacerW2900572Kit 599910
23Rocker BearingW5865432Kit 599910
24Rocker Pivot SleeveW3101551Kit 599910
25Rocker Axle NutW3115821Kit 599910
26Main Pivot Axle5990991Torque 30NmKit 599909
27Main Pivot SpacerW4409212Kit 599909
28Main Pivot BearingW3020252Kit 599909
29Main Pivot Sleeve5990991Kit 599909
30Main Pivot Axle NutW5841341Kit 599909
19Upper Shock SpacerW529969216x10x3mm
31Upper Shock Axle5998981
32Shock Mount BearingW2934664
33Lower Shock SpacerW5364142
34Shock Axle Nut5407552Torque 10Nm
35Lower Shock Axle5999001
36Thru Shaft BoltW5838044Torque 17Nm
37Charge Port CoverW5934451
38M3x10mm BoltW5934452Torque 1.2Nm
39Bosch Charging Socket Bosch 1
40Battery AssemblySee next table
41Upper Frame Bracket5800661
42M5 Locking Nut5998834
43M5x15mm5998834Torque 5Nm
Apply Grease to Head
43T25 Security Torx599883
44ABUS Lock CoreW5623111
45M5x16mm Bolt5792474Torque 5Nm
4615x5.3x2mm Washer5792472
47M4x8mm Bolt5792472Torque 3Nm
48Upper Docking Bracket5840971
49Battery Bumper5793262
50Ejector Assembly5793241Torque 5Nm
51Lower Frame Bracket5800661
52Lower Docking Bracket5840971
ARIB Battery Cover594607Olive Grey / Trek Black
ARIB Battery Cover594608Dnister Black / Rage Red
ARIB Battery Cover594609Volt Green / Teal
ARIB Battery Cover594610Teal / Nautical Navy
BHandle Assembly5726571
CSpring Cap5726571
DBattery Handle SpringW5772751
EM4x8mm Bolt5790926Torque 2.4Nm
FLower Battery CoverW5555881
GM3x20mm Bolt5790924
H500W RIB SpacerW5823231
IM4x12mm BoltsW5823234Torque 2.4Nm
J12x4x1mm Washer 4
53Bosch Drive Unit, Gen41
54Drive Unit Bolt, M8x16mm TX4012700160306Torque20Nm
55Motor ArmorW5869631
56M5x10mm Bolt5596604Torque 5Nm
518K
