Transporting a Rock Rider EST 900 in a car without removing wheels?
Hpsm
Hey everyone, ebike Transportation Inside the car without dismantling the wheel? Which European car?
My bike's a Rock rider est 900.
Hey everyone, ebike Transportation Inside the car without dismantling the wheel? Which European car? My bike's a Rock rider est 900.
@Hpsm, welcome to the forum. This is a question that comes up surprisingly often, and the answer depends entirely on how much car you're willing to throw at the problem.
The Rockrider EST 900 is a full-fat eMTB, so you're looking at roughly 25kg and the usual dimensions: around 1.8m long with wheels on, bars about 750-800mm wide. Fitting that inside a car without removing wheels narrows your options quite a bit, but it's not impossible.
The go-to cars for this in Europe tend to be estates or large SUVs with the rear seats folded flat. A Skoda Superb Combi or Octavia Combi will swallow an eMTB with wheels on if you drop the rear seats and angle the bike diagonally (bars turned, front wheel to one side). The VW Touran and Sharan are solid choices too, with the Sharan's sliding doors making loading less of a comedy routine. The Ford Tourneo Connect (the tall van-shaped one) is excellent for this, as is the Peugeot Rifter or Citroën Berlingo, both of which have enormous, boxy cargo areas that make wheel-on transport genuinely easy. If you want something more premium, the Volvo V60 or V90 estates have the length, though you'll want to measure the load aperture height carefully.
A few practical tips: turn the handlebars 90 degrees to reduce width, drop the seatpost if you have a dropper, and lay down an old blanket or a proper boot liner to protect both the car and the bike. Some people also deflate tyres slightly to squeeze past tight apertures, though that's a last resort. @vikino1 mentioned using a Thule rack on a Skoda Yeti for eBikes with batteries removed, which is worth considering as a backup plan if internal transport proves too tight. The Thule EasyFold XT is another option if you'd rather keep the interior clean, as @Giox noted it handles three big eBikes better than the Velospace and folds compact for storage, though that does mean external transport rather than inside the car.
If you can, I'd suggest visiting a dealer with a tape measure (or your actual bike) and doing a test fit before committing to a car purchase. The load aperture height is usually the limiting factor, not the length.
    668K
