Suspension set ups !!!
Gary
Old Tartan Bollocks
10,496
10,688
the internet
unless you just like reading pointless numbers read the suspension set-up sticky at the top of this very section of the forum
If that indeed ius the case here are some to keep you busy
285 98 50 68 86 19 84 94 95 89 86 94 83 98 68 38 6
they are are about as much use as a bunch of random people telling on random bikes with random shocks and forks telling you their preferred air pressures
Gary
Old Tartan Bollocks
10,496
10,688
the internet
Ok
I weigh 200, my fork is at 85 and my shock is at 205
this information alone doesn't help you in the slightest.
you really found this video too difficult to understand?
Was it Seb's accent?
... youtube has subtitles ;)
Simoto123
265
368
North west
I was just wondering what people where keeping there shocks at . The sticky just confuses me .. and those videos more so . A bit like the random numbers 10 4 6 7 8 10 . That's how much sense those videos make to me .
If you post your weight and the manufacturer and model of suspension and bike, you may get something like a baseline to work with. Gary is right, without this basic info the numbers are useless in themselves. The video he posted is very good and easy to work through.
Gary
Old Tartan Bollocks
10,496
10,688
the internet
no worries mate
but...
You do realise It's the very first video from the thread I asked you to read in the first place?
:ROFLMAO:
#lazy
E*POWAH BOSS
Oct 1, 2019
1,340
1,460
Trail ebike 15/20% sag F&R , Enduro ebike 20/25 sag ,Trail bike 20/25 sag , enduro 25/30 sag , DH 30/35 sag ! Give or take a pump or 2 , easy ! Forget weights and psi measurements until it feels right THEN write it down for reference ! IMO
HORSPWR
853
679
Alice Springs, Australia
I always try and make sure I set my front and rear so that on the maximum hits it is just a whisker from full stroke and then control my compression and rebound accordingly. Too many people run too much PSI to control bottoming out rather than their compression adjustment.
There's absolutely not point buying a bike with 160mm of travel in the front, whacking too much PSI in there and only using 120mm of travel..!!!
#lazy
E*POWAH BOSS
Oct 1, 2019
1,340
1,460
There absolutely not point buying a bike with 160mm of travel in the front, whacking too much PSI in there and only using 120mm of travel..!!!
Good point , I usually set the sag and then tune with tokens to get the big hits just short or max ( bottom out never did me any harm ?) !
Gary
Old Tartan Bollocks
10,496
10,688
the internet
@maynard
Ignore the bit about tokens in the video for now, and ignore the advice given here about them too.
Talking about tokens to a complete suspension novice is usually a big mistake*.
Very few folk (even a lot of riders very vocal about token use) actually understand their purpose properly. Not that they're particularly difficult to understand. But leave learning how to use them until you have set up the fork with suitable sag and ridden it a fair bit.
We still don't even know what bike or suspension the OP is running
*unless you're prepared to spend time listening to them and setting up their suspension for them
Gary
Old Tartan Bollocks
10,496
10,688
the internet
Yes there is.
I've run oversprung forks on many bikes from dirt jumpers to DH/slopestyle bikes.
But rather than send this beginner suspension thread off any more of a tangent I'll let you go away and try to work out why. ;)
HORSPWR
853
679
Yes there is.
But rather than send this beginner suspension thread off ony more of a tangent I'll let you go away and try to work out why. ;)
We all know you're the resident expert on all things global Gary and that you were a legend in your day and no one can ever match your achievements but for general ebike riding there isn't any need to over spring your bike, except in your case because you are the dirt legend!!
Gary
Old Tartan Bollocks
10,496
10,688
the internet
Take a little longer to think about the question before your next test.
8,632
I like a bit of spare travel just in case I over reach myself, or get trapped into a drop with no way out (it usually happens when following someone who is a better rider than me). Then I need all the help I can get.
RickBullotta
1,761
1,503
01001000 01010011 01000011 00100000 01100001 01101110 01100100 00100000 01001100 01010011 01000011 00100000 01110111 01101001 01100100 01100101 00100000 01101111 01110000 01100101 01101110 00001010
522K
