Here's what worked for me. Turn bike upside down with battery installed. Take off the bash guard. The battery nest adjustment bolts are underneath. The bash guard bolt also holds the nest so that is tightened last. The nest is held in place on just one side of the frame so you can imagine it can angle down on the other side and get out of square with the battery. loosen the bolts a bit and push the nest down on the far side with a thin tool. Hold the nest firm in place while tightening the two bolts. Replace bashguard and tighten the upper bolt as tight as you dare. Also apply dialectric grease to the terminals on the battery and the nest. this has worked for the last few hundred miles no problem and i did not get the new nest which also still has the same problem acording to some. Good luck.
