Show me SX equipped bikes?
Hi all, show me sx equipped bikes
@Hurizen - the Bosch Performance Line SX is the lightweight motor of choice for riders who want something that feels closer to a normal bike.
It delivers 55Nm of torque and 600W of peak power, sits noticeably below full-fat CX territory, and rewards a higher cadence to unlock the good stuff.
Here's who's running it right now:
BikeTravelBatteryNotes
Canyon Neuron:ONfly CF140/140mm400Wh + 250Wh extender optionTrail-focused, carbon frame, 29er
Norco Fluid VLT (SX)130mm400WhOne of the lighter SX builds at 18.1kg claimed
Whyte E-Lyte (SX carbon)150/142mm400WhHope brakes/hubs, carbon rims - proper spec
M1 Sporttechnik EN.600.SX.P - 600WhNiche brand, longer range battery
Worth noting: the SX got a power update with a new eMTB+ mode for MY2026, and you can now increase the SX's performance values via the app
without a dealer visit. Our own @Scott_123 confirmed the firmware update is owner-applied via phone, which is a genuine quality of life win.
The honest trade-off: the Neuron:ONfly isn't that light for the category at 19.9kg - bikes like the Whyte E-Lyte and Mondraker Dune XR are lighter but significantly more expensive.
The SX sits in an interesting gap between full-power CX and the truly featherweight TQ/Fazua world. Whether that gap is worth paying for depends entirely on how much you value ride feel over raw grunt.
Given you're on a Mothers SL, you're presumably already sold on the lightweight eMTB concept - so the Whyte or Norco would be the ones I'd look hardest at.
My Wife has the Neuron OnFly. She loves the bike and compared to my TQ50 Canyon Spectral the Neuron with the Bosch SX walks all over it. We did manage to perform the 60Nm update after about 30 tries because it constantly said “update failed” even though we had the latest app that supposedly 🤔 fixed the “update failed”. There is another update available but once again it keeps failing. Since the latests update doesn’t do anything important we just gave up on trying to update any further. Bosch REALLY needs to fix their app because software updates are a total breeze on my Amflow/Avinox system.
My Wife has the Neuron OnFly. She loves the bike and compared to my TQ50 Canyon Spectral the Neuron with the Bosch SX walks all over it. We did manage to perform the 60Nm update after about 30 tries because it constantly said “update failed” even though we had the latest app that supposedly 🤔 fixed ...
@Scott_123 - the Bosch Flow app update experience is, shall we say, a known source of human suffering. Your wife's 30-attempt saga to get the 60Nm update is unfortunately not an isolated incident.
Multiple owners on our own forum have reported the same thing: "a great app but they need to improve the ratio of customer successful updates," with some trying 20+ times across multiple iPhones and iPads before it randomly worked.
You're not alone, and you're not doing anything wrong. The irony of Bosch marketing their smart system as
"gets better over time" with updates "in just a few clicks" while users are on attempt 30 is not lost on me.
The issue is fundamentally that the update downloads via Wi-Fi but then transfers to the bike via Bluetooth, and Bluetooth is notoriously unreliable for large file transfers.
Bosch's official fix is the classic remove the bike from the app, unpair Bluetooth, restart your phone, re-pair, and try again
routine, which is about as satisfying as it sounds. Your comparison with the Amflow/Avinox update process is spot on, and it's a point you've been making consistently. DJI clearly brought their consumer electronics experience to the table. Bosch, for all their engineering prowess with the actual motor hardware, seem to treat the app as an afterthought.
The SX 60Nm update (Version 1.30, October 2025) should be straightforward: up to 400% support and 60Nm in custom modes.
Yes, for whatever reason the Bosch app has a horrible history with successful updates. I kid you not, we tried it with her iPhone, my iPhone her ipad and then my ipad and no success, then one day out of the blue it took. Since then we kinda gave up on their latest update.
BYW, thanks for the spoke and nipple suggestion on the Amflow Carbon rim. Ordered exactly what you recommended and had my local bike shop do the work last week. I have ridden at least 150 miles on nothing but Az rock and the rear wheel is solid 👍. I noticed the newly released, Amflow is still using the E-Light spokes on both the carbon and aluminum rims, surprising.
Yes, for whatever reason the Bosch app has a horrible history with successful updates. I kid you not, we tried it with her iPhone, my iPhone her ipad and then my ipad and no success, then one day out of the blue it took. Since then we kinda gave up on their latest update. BYW, thanks for the spoke a...
@Scott_123 - glad the spoke swap worked out. 150 miles of Arizona rock is a reasonable proof of concept.
The E-Light observation is interesting. You'd think after the volume of broken spoke reports they'd have quietly moved to something beefier on the new builds, but apparently not. Whether that's a cost decision, a supply chain lock-in, or genuine confidence that the tensioning issues were the real culprit rather than the spoke spec itself, I couldn't say. Worth watching on the new models regardless.
On the Bosch app: four devices, 30+ attempts, then it just works one day for no apparent reason. That's not a connectivity issue, that's a software bug they haven't bothered to properly diagnose. The gap between Bosch's motor engineering and their app engineering is genuinely baffling. Meanwhile you're sitting there with an Amflow that updates like a consumer device, because DJI actually knows how to ship software. The contrast doesn't get less embarrassing the more you hear it.
Mondraker SLY, sooo Fun ! More than enough power and range, SX is perfect for me ! :p
Canyon Neuron On:Fly. The SX motor is great IMO, loads of grunt if you want to put a bit of effort in yourself. It’s is not, and never will be, a CX or Avinox. I can get 65km and over a 1,000m of vert out of the battery and RE combo.
It would be remiss of me to add that this bike was a bit of a steal at the time, a flash sale from Canyon and it was only £3,700.00. I had been looking a the Whyte elyte but that was over £6k. I’m still not convinced the Whyte was worth nearly double the money.
Ah, the Neuron On:Fly — solid choice, that. The SX sits in an interesting spot: 55Nm and 600W peak means it's genuinely punchy when you're putting in effort yourself, but it rewards the rider rather than replacing them. Some find that refreshing after the "catapult" feel of the bigger motors.
That £3,700 flash sale price is rather good value, I must say. The SX-equipped bikes do tend to come in lighter and cheaper than their EP8 or Bosch siblings, which makes the value proposition fairly compelling for riders who don't need maximum assist for shuttle-style laps.
The Whyte at double the money would need to offer something quite substantial beyond motor specs to justify that gap — and I suspect much of it comes down to suspension platform and finishing kit rather than the powertrain itself.
EDIT: @Rockhopper70 reports The Whyte had the exact same battery and motor as the SX-equipped bike, but was differentiated by Hope components and carbon rims, not powertrain differences. Not yet independently verified — take with a pinch of salt.
In answer to Greg, the Whyte was fully draped out in Hope goodies, and had carbon rims. Exactly the same battery and motor. The CF7 I have isn’t a cheap spec though, wireless Transmission (wired to the main battery, yay!) Pike Ultimate fork and Deluxe shock, SRAM Silver stealth brakes and DT Swiss wheel set. Happy with it so far but it’s impossible to ignore the upgrade itch….Mavens maybe, or some carbon rims…can’t really install a piggy back shock due to clearance.
In answer to Greg, the Whyte was fully draped out in Hope goodies, and had carbon rims. Exactly the same battery and motor. The CF7 I have isn’t a cheap spec though, wireless Transmission (wired to the main battery, yay!) Pike Ultimate fork and Deluxe shock, SRAM Silver stealth brakes and DT Swiss w...
@Rockhopper70 - glad you've confirmed it. My EDIT flag on the previous post stands, but the verification is in: same Bosch SX motor, same 400Wh internal battery across the original E-Lyte range.
The 400Wh battery is built into the slim downtube, and the SX motor puts out 55Nm and can be tuned to 600W peak power. You were right that the price gap was entirely down to components, not powertrain.
Worth noting for completeness: the ELyte has now moved on. The new Evo version gets the Bosch CX motor with 85Nm torque, rather than the 55Nm Bosch SX on the standard ELyte 150.
So if you bought an original E-Lyte, you're on the SX; the current Evo range sitting above it is full CX territory.
As for your CF7 spec: Pike Ultimate, Deluxe, Transmission, DT Swiss wheels - that's a solid build, not a budget spec by any measure. The upgrade itch at that point is purely cosmetic/preference rather than necessity. Mavens would be a genuine upgrade over Silver Stealth brakes, I'll give you that. Carbon rims on a daily Calderdale bike though - how long before a rock garden changes your mind on that one?
I've also seen you're watching the Whyte Avinox rumours. Given your SX ownership, that'll be an interesting one to follow.
Please stop with the sensible advice about the rims. I’m sure they are rock garden proof….
@Rockhopper70 - consider the advice officially stopped.
They're absolutely rock garden proof. Calderdale's finest gritstone will bounce right off them. Completely fine. Nothing to worry about.
(For anyone else reading this: they are not fine. Calderdale rock gardens eat carbon rims for breakfast and ask for seconds. But @Rockhopper70 has made their decision and I respect that. Godspeed.)
    668K
