Welcome aboard, @WillD93. Right, the bad news first: a 205 x 57.5mm shock is wrong for the Fuel EXe. The frame is designed around 205mm trunnion mount with stroke options of 60mm (140mm travel), 62.5mm (146mm travel), or 65mm (152mm travel). 57.5mm isn't one of them, so you'd lose around 6mm of rear travel versus stock - the bike would sit higher in the rear, steepen the head angle, mess with the kinematics, and generally feel like it's wearing the wrong size shoes.I want to fit my 205mm eye to eye, 57.5mm stroke length RockShox Super Deluxe Coil shock to my Trek Fuel EXe 8. Will it fit okay? And will the stroke length reduction cause too many issues?
So the shock measures up as 205mm for Trunnion mount, im not overly concerned about losing the 6-7mm of travel, im not overly aggressive as a rider anyway, and the shock is currently fitted with a 500lb spring, which could be changed if required. Im more overly concerned about clearances.Welcome aboard, @WillD93. Right, the bad news first: a 205 x 57.5mm shock is wrong for the Fuel EXe. The frame is designed around 205mm trunnion mount with stroke options of 60mm (140mm travel), 62.5mm (146mm travel), or 65mm (152mm travel). 57.5mm isn't one of them, so you'd lose around 6mm of rear travel versus stock - the bike would sit higher in the rear, steepen the head angle, mess with the kinematics, and generally feel like it's wearing the wrong size shoes.
The other issue is mount type. The Fuel EXe takes a TRUNNION mount shock (bolts directly into the upper mount, no eyelet). If your Super Deluxe Coil is a standard eye-to-eye 205mm, it won't physically bolt to the frame at the top. Worth double-checking what you've actually got - 205 x 57.5 trunnion isn't a stock RockShox size I'm aware of, so it may be a 230 x 57.5 eye-to-eye that you've measured differently.
If you want the coil feel on the EXe, the right answer is a Super Deluxe Coil in 205 x 62.5mm trunnion. @Rob Rides EMTB confirmed that exact size fits the Fuel EXe, and @jluu noted 62.5mm gives better clearance in the low setting than 65mm. Sell what you've got, buy the right one - annoying but cleanest outcome.
Happy to dig into spring rate for your weight or tuning recommendations if you go that route.
Good news on the mount: clearance is the real conversation to be having. Your 205 x 57.5mm trunnion will bolt straight in, the mount hardware is the same. The issue is what happens to the reservoir when the suspension cycles.So the shock measures up as 205mm for Trunnion mount, im not overly concerned about losing the 6-7mm of travel, im not overly aggressive as a rider anyway, and the shock is currently fitted with a 500lb spring, which could be changed if required. Im more overly concerned about clearances.
