Shimano STEPs and Garmin Forerunner 935
DrChris
40
20
I've noticed that when I start a ride that I get a notification on my Garmin Forerunner 935 watch that it has synced with with my Shimano STEPs motor.
But I can't see any way on my Garmin 935 of viewing any of the same stats as my Shimano display, or anything remotely related to by eBike.
Has anyone else managed to make use of their Garmin watch with their Shimano Ebike?
All I have found is this:
Garmin® announces SHIMANO STEPS support on Edge® cycling computers to help enhance the eBike riding experience | Garmin International
DrChris
If38
11
9
France
Same question here! My Garmin 935 found my Commencal Meta power automatically as a Di2 product. Don't know what stats could I follow? Battery state?
mark.ai
828
593
Windermere
Do you both have E8000 display and Di2 gears?
- your watch can probably display the Di2 rear gear number and also the Di2 battery percentage (which if your Di2 is connected to main ebike battery will actually be your main ebike battery percentage). You would need to add some custom fields showing Di2 information (see page 24 of this manual: http://static.garmin.com/pumac/Forerunner935_OM_EN.pdf)
Or E7000 display / EW-EN100 junction instead of display?
- if you have this and it connects to your watch I want to know more :)
If38
11
9
France
I have tried several configuration and the only stats showed on the watch is, as indicated by @mark.ai , the battery state.
For that you have to set up Di2 battery as data fields, it shows actually battery state of the bike.
All other stats works only with Di2 gears.
It could be great if specific data field such as Ebike field could work with shimano steps motors! @JanCapek , any plans to work on that?
mark.ai
828
593
Windermere
I've got the E8000 display but I'm not running Di2 gears - I have a Commencal Metapower too.
So does this mean that with just E8000 display and no Di2 gears you can still display the ebike battery (as Di2 battery) on your watch? It's really interesting to know if that's the case :)
If38
11
9
France
Exactly! I can confirm it's working on my Commencal Meta power
JanCapek
157
138
Czech Republic
Hi, I would love to have Shimano motors compatible with my Ebike Apps. But Shimano unfortunately decided to use private communication standard as opposite to open ANT+ LEV. I still may find a way how to make connectivity working with the Shimano using reverse engineering but the result is unsure and it takes a lot of time, so now it is not possible to connect my apps with Shimano.
@mark.ai remind me please, when you are connecting with your EDGE 1030 to EW-EN100 - you are pairing it as Shimano Di2 sensor in your Garmin?
mark.ai
828
593
Windermere
It connects as an "eBike" not as a normal "Di2" sensor - but lists as "Shimano STEPS" once connected.
I'm still wondering if Bluetooth might be better to try using to connect - I'll probably give it a go when the new CIQ SDK is released.
518K
