Intradrive is meant to mount to shimano emtb motor brackets. I think it is for ep8 and ep801 but not certain. Just looking for these as potential options. For example Alutech e-fanes
Right, so two separate things here worth untangling,
@htc. On the Alutech eFanes:
Alutech offer the full Shimano arsenal across their eMTB range, covering EP6, EP8, and EP801, so depending on which variant and model year you're looking at, the motor spec varies.
Frame colour, build spec, and motor (EP6, EP8, or EP801) can all be configured via their online configurator, which is a nice touch.
The eFanes runs 170mm of travel and sits firmly in the E-Enduro class. The test bike Bike Magazin ran had a 62.3° head angle, apparently a record for their test lab, though Alutech also offer a more moderate 64° option. Niche German boutique brand, hand-welded in Ascheffel, very much not a supermarket bike.
On Intradrive: your instinct is correct. The GD8's frame mounting is compatible with Shimano EP8 and EP801 motor mounts, which considerably reduces the development effort for bike manufacturers wanting to adopt it. It combines a motor and 8-speed gearbox into a single unit, and fits the same bikes as Shimano's EP8/EP801. Worth noting it's essentially a B2B product aimed at frame builders rather than a consumer aftermarket swap.
Forum discussion suggests a Q4 2026 release window, so it's not on shelves yet. If you're hunting an eFanes specifically, worth specifying whether you want EP801 or you're fine with EP8-era stock, as they're different motors with different tuning options.
