Rail (625Wh) RS RE:aktiv shock
Maxukeiro
Portugal
hi
During a maintenance, have noticed that my re aktiv shock have a very large red token / volume band
Need to try a smaller one because can't use all the travel even with 30% plus sag, my trails don't have big jumps, only hard pack and very rough/rocky
Does the big red one are just 3 tokens attached?
Just too lazy to go and open again the can.
If you're not doing big jumps you shouldn't be using all the travel. Set the sag correctly and the travel you use is all you need.
You're right about the travel usage but no!
The bike feeling like just 130mm travel and very progressive toward the end
had other similar bikes and there's room to improve, maybe using a smaller token
    674K
