Twisted Fork
A few months ago I replaced the OEM 205x60 Deluxe Select+ shock on my mulleted Fuel ex-e with an overstroked 205x65 Super Deluxe Ultimate (2025 version). The new shock came fitted with the linear air can, so I installed it in that configuration first to try it out (and to be honest, because at the time I had no idea what the extra air can included in the box was for).
I set it up at 28% sag with 160 PSI in the linear air can, 2 volume tokens, -10 clicks of rebound, -1 LSC, and +1 HSC. It felt quite good overall and was nice and plush through the initial and mid-stroke while having enough bottom out resistance to handle the 1.5m drop-to-flat on my favourite afternoon ride loop. However, I found the mid-stroke not to be as playful and poppy as I want, so it was a bit muted getting airborne off of rollers and trailside kickers. Adding any more clicks of rebound started to pitch me forward off the lip too much.
I recently swapped in the progressive air can while getting its first service, hoping for a bit more lively mid-stroke while keeping the bottom out resistance. I’m hoping to replicate the mid-stroke feel of the original 60mm shock (180 PSI with progressive air can, 7 clicks of rebound, 1 token) while adding much-needed bottom out resistance and the extra 12mm of travel that comes with the over-stroked shock.
I was a bit surprised that it took 195 PSI in the progressive air can of the SDU to get me to 28% sag. Does that sound reasonable? I reset HSC & LSC to neutral for a start and dialled the rebound back to 8 clicks. I haven’t had the chance to do a proper gravity ride on it yet due to mucky, thawing trails. It certainly feels stiffer on the initial stroke at that pressure, whereas I thought the progressive air can was supposed to have a more plush initial stroke. Can you offer me some suggested starting points to get me close to where I’d like to be?
Rider weight is 180 lbs, bike weight is 39 lbs, 160mm Lyrik fork.
