Replacement rear axle for cube stereo hybrid?
Bummers
516
469
I'm wanting to change the rear axle for a quick release one. It's 148x12 but any idea where I find what thread it is?
Bike is a cube stereo hybrid 160 action team 2022.
Justinitus
55
88
Wiltshire UK
Can’t help re the thread pitch, but some Trek bike thru axles come with a hex lever that’s held in by a strong magnet, just pull it out if you need to do the other wheel. My Trek Farley fat bike had one, really good little gadget. A Trek dealer should have them.
Landy Andy
191
190
Herts
These work well. Just fitted a pair to mine. My thread pitch and details were on the existing axle.
Bummers
516
469
If it’s M12 then you could compare to a standard bolt which would be 1.75, and if finer a 1.5 pitch.
This is all the details on it. Seems to be a finer pitch than the front axle.
Bummers
516
469
Looks like it could be a very fine thread of 1.0
Yes! Appreciate the help. Doing some digging it seems to be m12 x 148 with a 1.0 pitch.
This site seems really useful as well:
Landy Andy
191
190
Herts
I‘m sure you know but if not. Being a pitch of 1.0 means each mm there will be a high to high, or low to low, point on thread. So 10 threads per 1cm
if that makes sense
Bummers
516
469
if that makes sense
Nope, i don't fully understand thread pitch tbh. I vaguely remember being shown how to identify different pitches on my apprenticeship many years ago.
Easier now just to use a thread checking tool - except I'd left it at work and didn't have it to hand. 😄
Colin1517
50
101
Lancashire
@Bummers did you manage to track down the quick release for your Cube?
I’m looking to change the front and rear on mine and you could save me a few hours searching online pal 👍
Bummers
516
469
Yes! So the rear is:
Which is boost 148mm length with 15mm of thread with a M12 X1 pitch. (12mm diameter axle)
(Overall 163mm length)
The difficulty is sourcing one. Only DT Swiss make them and I bought mine from wiggle but they've not been in stock for ages.
That looks like the right one, just remember the 1mm pitch.
Front quick release depends which forks you have, for the fox 38's you need a kit with the quick release that provides bushes for it to fit correctly.
What bike do you have?
Colin1517
50
101
Lancashire
Thanks for this. I have the 2022 Hybrid 160 SL with Zeb’s.
Bummers
516
469
You'll need to dig through the manual and find the axle spec, it'll probably be 15x110mm boost but you'll need the thread pitch details. Check your existing axle in case it's printed on.
Once you've got the details it should be straight forward to then search for a quick release.
518K
