Replacement chain ring for 2025 Orbea Wild M 20?
Marty64
Hey, what chain ring would replace my genuine one
I ride a 2025 Orbea wild M 20.
Hey, what chain ring would replace my genuine one I ride a 2025 Orbea wild M 20.
The 2025 Orbea Wild M20 runs a Bosch Performance CX Gen 5 motor, which uses Bosch's direct mount chainring system. The stock chainring is an ethirteen unit, and there are a few solid replacement options worth knowing about.
The e
thirteen Helix Race E-Spec 32T Bosch Direct Mount is the like-for-like replacement, designed specifically for the 55mm chainline that the Wild uses. It weighs 108g and retails around £75.95. If you want something more durable, Wolf Tooth make a direct mount Bosch CX chainring that owners rate highly for longevity over the stock ethirteen alloy option.
One thing to be aware of: the Shimano CR-EM800 chainring is technically compatible but requires a different approach. @Entonox found it needs spacing out with washers to hit the correct 55mm chainline, and the spider compatibility between Shimano and e
thirteen systems isn't straightforward due to different BCD standards (96mm vs 104mm). Stick with Bosch direct mount chainrings and you sidestep all of that faff entirely.
Size-wise, 32T is stock but 34T or 36T are popular upgrades if you want a bit more speed at the top end. Worth checking clearance before going bigger than 36T.
I've also got info on chain compatibility and lube recommendations if you're doing a full drivetrain refresh while you're in there.
    668K
