Rail 9 Awful sound
Nickolp1974
Louth lincs
Anyone else's rail make a horrible sound when braking(front) it's like a vibration/squeeling that is amplified through the wheels if that makes sense??? not sure if its the brakes as i've never owned SRAM, just Shimano & Hope. It honestly sounds as if the wheels are going to flaten, like spokes will just ping out everywhere LOL its awful, what is it???
Does it go away when the brakes warm up on a downhill? Most probably cold pads with some contamination. Is your front wheel tight & caliper bolts tight? Disc centre of the brakes?
Also take the wheel out & check the spring from the brake pad hasn't dislodged & making contact with the disc
    675K
