Quick release for front wheel - Cube Stereo Hybrid?
Major Stare
130
189
Nottinghamshire
I have a 2021 Cube Stereo Hybrid 160 hpc race 625 and would like a quick release front wheel.
Quick release, boost, non boost, different dimensions and sizes, im struggling to work out what i need.
I have a SeaSucker coming next week and would like to make things easier with removing the front wheel.
6,158
4,683
Its a Rockshox fork so standard is a Maxle and from your comment it is a Maxle Stealth ( ie needs allan key to do and undo)...there are a couple of lever action versions of the Maxle. Check the dimensions which are often printed on the existing thru axle if you want to buy something at less cost like a Brand X which is most likely to be Brand X option 7 .......or measure the overall length and length of the threaded section on your existing maxle to get a match. It will be 110x15 (boost) , M15x1.5 thread pitch and probably 158mm total length.
Major Stare
130
189
Nottinghamshire
It appears I do have a Maxle.
Length 158mm
TP (width?) 15mm
524K
