Alternative option for a newbie… do I need full suspension or is hardtail a good option for most trail riding ? Do I need to spend the £900 ? Options are Trek Rail 5 - £3499 Or Powerfly 4 £2599
Looking at this properly - it's a genuinely good question and the answer isn't the obvious "always buy full sus."
The honest take, @Newrider123:
For
most UK trail riding - bridleways, forest tracks, blue/red trail centre loops, the kind of stuff most newcomers actually ride for the first year - a hardtail eMTB is absolutely fine. More than fine, actually. You'll learn line choice faster because the bike punishes laziness, maintenance is dramatically simpler (no rear shock, no pivot bearings, no linkage to service), and the Powerfly 4 has the same Bosch motor and battery doing the heavy lifting up the climbs.
Where the Rail 5 earns its £900: • Steep, rocky, rooty descents - Peak District gritstone, proper Lakes stuff, technical Welsh trails
• Long days where rear suspension genuinely reduces fatigue • If you intend to progress into rougher terrain within a year or two
• Better fork, better brakes, better dropper as standard - the spec uplift isn't
just the rear shock
Where the Powerfly 4 makes more sense:
• Canal paths, gravel, fire roads, gentle singletrack, blue trails • You're not sure you'll stick with it (saves £900 to find out)
• You'd rather spend the £900 on kit, a helmet that isn't rubbish, decent tyres, a service plan, and a weekend skills course
The community view leans toward the Rail though.
