power mode dropping out on a Orbea Wild
Woody 13
Hi Greg, i am new to E bikes and purchased a Orbea wild in November. i have been out on it twice (due to weather) and covered 44 miles on it. During the both rides the power mode keeps dropping out for no reason and can do it at any time or place.
I took it into my dealer and they cannot find any faults on it.
Has this issue happened to anyone else in the past? Regards Steve
Hi Greg, i am new to E bikes and purchased a Orbea wild in November. i have been out on it twice (due to weather) and covered 44 miles on it. During the both rides the power mode keeps dropping out for no reason and can do it at any time or place. I took it into my dealer and they cannot find any fa...
Welcome to the forum, @Woody 13, and congratulations on the new Wild. Less congratulations on the intermittent power dropout, which is one of those gremlins that can be genuinely maddening, especially when the dealer plugs it in and everything looks fine on the diagnostic.
First things first: which year and spec is your Wild? The Orbea Wild has always run Bosch motors — the 2025 models use the CX Gen 5 (100Nm, 750W), while older shapes ran the Gen 4. Either way, the troubleshooting steps below apply to both.
That said, intermittent power cuts with no stored error codes is a pattern I've seen discussed across multiple brands, and it almost always comes down to one of three things:
Battery-to-frame connection. This is the most common culprit. The battery sits in the downtube and the contacts can develop micro-gaps from trail vibration, especially on newer bikes where everything hasn't quite bedded in yet. Community members have found that power cuts during vibrations (bumps, roots, rough terrain) point squarely at the battery-to-harness connection. It's worth removing the battery, inspecting the contacts for any debris or corrosion, giving them a clean with contact cleaner, and making sure the battery clicks firmly back into place with no play whatsoever. Some people add a thin strip of electrical tape to the battery housing to shim out any slop, though check with your dealer before doing anything that might affect warranty.
Wiring loom and connectors. eMTBs have a lot of wiring running through the frame, and a loose or corroded connector anywhere in the loop can cause intermittent dropouts. On Orbea's enclosed wiring system in particular, if any wire or connection is bad anywhere on the bike, motor, or battery, things can get unpredictable. Ask your dealer to specifically inspect the connector behind the motor and any junction points in the downtube, not just run a diagnostic scan. A visual inspection with the covers off is worth more than a software readout for this kind of fault.
Speed sensor. If the bike is losing its speed signal intermittently, some systems will cut motor power as a safety measure. Check the gap between the speed sensor on the rear wheel and its magnet, and make sure the magnet hasn't shifted on the disc.
Given that your dealer found nothing on the diagnostic, I'd push them to do a physical inspection of all the electrical connections with the covers removed, rather than just plugging it in and reading codes. Intermittent connection faults rarely throw a stored error, they just quietly ruin your ride. If it keeps happening, document exactly when it occurs (climbing, rough terrain, specific battery level) as that pattern can narrow things down enormously.
Let me know how you get on.
Hi Greg,
thank you for the welcome and informative advice.
i am sure its a gen 5 from 2025.
the drop out can be on any surface and any mode, i took about 20 mins before it happened on the last ride out and then it was just random in any mode unfortunately.
the dealers are hoping to give it a good ride out tomorrow and see if it happens to them, if not we are going to try and change a part at a time and see which one is causing it. This is not ideal when you spend that kind of money but i am will to help them out at the moment.
I will let you know once i have any feed back from them.
Regards
Steve
Hi Greg, thank you for the welcome and informative advice. i am sure its a gen 5 from 2025. the drop out can be on any surface and any mode, i took about 20 mins before it happened on the last ride out and then it was just random in any mode unfortunately. the dealers are hoping to give it a good ri...
That process of elimination approach sounds sensible, Steve, though I do sympathise with the frustration of essentially beta testing a £6k+ bike. The fact it's completely random across modes and surfaces rather than tied to specific triggers does narrow things down - rules out speed sensor issues or mode-specific software glitches.
The community knowledge on intermittent power cuts without error codes consistently points back to physical connections rather than software faults. What you're describing - working fine for 20 minutes then cutting out randomly - is classic behaviour for a connection that's just barely making contact. Could be the battery-to-frame harness, could be a connector deeper in the system that's developed a micro-fracture or corrosion spot.
Good that they're planning to actually ride it rather than just plug in the diagnostic tool. Half these intermittent faults never show up on a static bench test. If they can't replicate it tomorrow, the systematic parts swapping is probably the right call, starting with the battery since that's the easiest swap and the most common culprit.
Keep notes on exactly when it happens during their test ride if you can - specific terrain, power demand, bike position. Even if the pattern seems random to you, there might be a subtle trigger that becomes obvious when someone else is looking for it.
Hi Greg
added a new controller and forgot to pair it up so it was an interesting ride on Saturday. Bike is bake with them for a couple of weeks, so hopefully they can get this resolved.
Regards
Steve
Hi Greg added a new controller and forgot to pair it up so it was an interesting ride on Saturday. Bike is bake with them for a couple of weeks, so hopefully they can get this resolved. Regards Steve
Ah, the classic unpaired controller scenario! @Woody 13, I can only imagine the confusion when the bike suddenly decided to ignore your input entirely. At least you've got a proper diagnostic mystery for the shop now rather than the intermittent gremlin we were chasing before.
Two weeks with the dealer should be enough time for them to properly trace whatever's been causing the random dropouts. If the new controller was genuinely the culprit all along, you'll know fairly quickly once it's paired and you're back on the trails. If the issue resurfaces after a few rides, then we're back to investigating battery connections or harness issues.
Hope they sort it properly this time - nothing worse than that nagging doubt every time you head out whether the bike's going to behave itself or leave you pedalling 20kg of dead weight home.
Is it a total power loss or just the assistance? My battery was faulty, which caused the bike to turn off while I was riding. After a battery replacement, the bike is working perfectly again
    668K
