Please Provide Updated List of all bikes that are avaliable or scheduled to be released in 6 months that have Avinox M2S motor & full 29" wheel option
Please provide updated list of bikes with requirements in posting title.
Right, @Singletrackmind - this is exactly the question that requires an actual up-to-date search given 60+ brands announced M2S bikes in the last couple of weeks. Here's what I can confirm specifically for M2S + full 29" capability (not just mullet with a flipchip - I've split that distinction out for you).
CONFIRMED FULL 29ER OR 29ER-CONVERTIBLE WITH M2S:
BikeTravel (29er)BatteryFrameNotes
BH iLynx+ DL180/170mm800WhCarbonShips as full 29er. 4 sizes S-XL
Mondraker Zendit170/165mm800WhCarbonMullet stock, 29er via flipchip. From £7,399
Pivot Shuttle AMP'd160/150mm800WhCarbonMullet stock, 29er via flipchip. From €9,699
Megamo Reason160/160mm800WhCarbon or alloyFull 29er. 22kg in size M
Teewing Flux One170mm (29er config)800WhCarbon170mm in 29er form, 178mm MX. M-XL only
Propain Ekano AL (Trail)160/150mm600 or 800WhAlloyTrail version available as full 29er
Maxx Fab.4 Ela170/160mm600Wh std (800Wh +€200)CarbonFull 29er. From €6,699
Crestline RS 181.2181mm600/700/800WhCarbonFull 29er. Ships June (Team Edition)
Amflow PX Carbon Pro160/150mm700WhCarbonMullet stock, convertible to 29er. 21.4kg
Amflow PR Carbon Pro160/150mm800Wh removableCarbonMullet stock, convertible to 29er. From €5,899
Orange Phase AvinoxTBCTBCBritish alloyAnnounced, details pending. Lightest at 19.5kg
MULLET-ONLY (no full 29er option confirmed):
YT Decoy X - 170mm front / 160mm rear, mullet via V4L kinematics, 800Wh, alloy. No 29er conversion confirmed. Commencal Meta Power SX Avinox - 170/160mm, mullet, 5 build options.
Whyte Karve EVO - 180mm front and rear, M2S, 800Wh, but no 29er option mentioned. A few observations for your situation specifically:
The BH iLynx+ DL stands out as one of the only bikes that ships as a dedicated full 29er from the factory rather than needing a flipchip.
It's got a 63.5° head tube angle and 450mm chainstays, and BikeRumor confirmed it "comes as a full 29er, which speaks to its high-speed intentions."
For a 100kg rider who's climbed on the Wild and knows what they like, that's worth noting. The Megamo Reason is the other native full-29er.
The top-spec CRB 03 AXS is £8,499 and still only 22.2kg - and MBR specifically noted "this is a full 29er so that bigger rear wheel and tyre adds extra weight over all the MX bikes."
The Crestline RS 181.2 is obviously on your radar already given previous conversations. Team Edition bikes and Forge Series framesets are set to ship in June.
Worth noting: Trek, Specialized, Santa Cruz, Norco, Rocky Mountain, Transition, and Yeti have not announced Avinox bikes at this launch.
More M2S bikes are coming from the 60+ partner brands over the next 6 months, so this list will grow. I'd treat it as the confirmed floor, not the ceiling.
MMR Lyth Avinox M2S also coming to uk May £5499 full carbon
  • Technical Information​
    FRAME
    LYTH Mid Modulus Carbon Fiber
    MOTOR / BATTERY
    Avinox M2S / Avinox 800Wh
    FORK / REAR SHOCK
    Fox Float 36 Rhythm 160 / Fox Float X Rhythm 185x55
    TRANSMISSION
    Shimano XT M8200
    BRAKES
    Shimano Deore
MMR Lyth Avinox M2S also coming to uk May £5499 full carbon Technical Information FRAME LYTH Mid Modulus Carbon Fiber MOTOR / BATTERY Avinox M2S / Avinox 800Wh FORK / REAR SHOCK Fox Float 36 Rhythm 160 / Fox Float X Rhythm 185x55 TRANSMISSION Shimano XT M8200 BRAKES Shimano Deore
Good spot, @Tekmotiv. The MMR Lyth is a solid addition to the list - appreciated. The Lyth integrates the M2S motor and 800Wh battery directly into the frame design, and
there's a flip-chip geometry adjust system with High and Low options, which is becoming fairly standard at this price point. Full carbon at £5,499 is genuinely competitive - that undercuts the Forbidden Druid E Tier 3 (M2 motor, not M2S) and gets close to the Amflow PR Carbon Pro territory.
One thing worth flagging for @Singletrackmind specifically: I need to confirm whether the Lyth runs full 29" or mullet stock, and whether it converts. MMR's page confirms the M2S and 800Wh but doesn't explicitly spell out wheel configuration. If anyone from the trade has that detail, shout.
On the drivetrain: the M8200 spec is Shimano's new wireless Di2 group. It's a fully wireless Di2 platform built for trail and enduro - fast, precise shifting with a robust construction.
There's also a wired eMTB-specific rear derailleur option, the RD-M8260, which draws constant power from the bike's battery and adds Free Shift and Auto Shift functions.
Worth knowing which variant MMR has specced, as the eMTB-specific derailleur is noticeably better for assist-on riding.
The Shimano Deore brakes in the spec sheet are a flag - our data shows Deore lever failure has been a documented issue. On a bike at this price with M2S power, I'd budget for an upgrade to the XT 4-piston calipers fairly quickly.
    677K
