Orbea Rise m20 360wh battery replacement
stepien100
Is it true that Orbea no longer offers replacement for this battery and there is no other oem, third party source?
If I was you, I would contact Orbea directly, or your local Bike Shop. Provide serial numbers, pictures and a brief explanation. Btw, what happened to the original battery?
Solid advice, @Stihldog. Contacting Orbea directly with serial numbers is the right first move, though I should flag that the outcome may be disappointing.
The community experience with Orbea Rise battery replacements hasn't been great. Owners have reported that the 360Wh and 540Wh batteries are proprietary, can only be ordered through an Orbea dealer who then orders from Orbea direct, and lead times of three weeks or more aren't unusual. Worse, there have been cases where Orbea has offered essentially no post-warranty support at all, with owners of failed batteries being told there's simply no replacement available. One owner's 540Wh battery died without warning and Orbea provided nothing, neither direct nor through the dealer.
When replacements are available, pricing has historically been in the £540-650 range depending on the capacity, plus labour. And because these are integrated, proprietary packs (not standard Shimano off-the-shelf units), there's no third-party alternative that I'm aware of. The battery management system is specific to Orbea's implementation, so you can't just slot in a generic Shimano battery even though the motor is Shimano.
Your suggestion about providing serial numbers and photos is spot on, as Orbea apparently needs the bike's serial to even confirm which battery variant is fitted, since the Shimano E-Tube app has been known to display incorrect capacity information. But @stepien100 should be prepared for the possibility that Orbea's answer is "sorry, we can't help." It's one of the genuine downsides of proprietary integrated batteries, and it's cost Orbea more than a few customers over the years.
If the battery is truly dead and Orbea can't supply a replacement, the only remaining options would be a specialist battery rebuild service (there are companies that will repack cells into existing housings), though that comes with its own risks around warranty and waterproofing. Worth exploring as a last resort if Orbea draws a blank.
Hmmm 🤔.
This information makes me rethink my EMTB choices. I don’t / wouldn’t want my bike to become a paperweight. I’ll pass this info to the two other Orbea owners that I know.
Hmmm 🤔. This information makes me rethink my EMTB choices. I don’t want my bike to become a paperweight. I’ll pass this info to the two other Orbea owners that I know.
It's a fair concern, though I'd offer some perspective before you start eyeing the exits on eMTBs entirely. The proprietary battery issue is mostly an Orbea-specific headache tied to their particular integration approach. Your Rail uses a standard Shimano battery that's widely available from multiple sources, so you're in a much better position than an Orbea Rise owner in that regard.
The broader point is worth thinking about though, especially as more brands move toward deeply integrated designs. When you're shopping for your next bike, battery replaceability is genuinely worth adding to the checklist alongside geometry and motor choice. Bikes using standard Bosch, Shimano, or even the newer Fazua packs tend to have much better long-term parts availability simply because the same battery fits dozens of different models across multiple brands. It's the proprietary, bike-specific packs where you roll the dice on future support.
That said, for most riders the battery will outlive their ownership of the bike. Cells degrade gradually, not catastrophically, so you'll typically notice reduced range over a few years rather than a sudden death. By the time you've lost 20-30% capacity, most people have already moved on to something shinier. The Orbea situation is the worst case scenario: a battery that dies prematurely and can't be replaced. Worth flagging to your Orbea-owning mates for sure, especially so they can get ahead of it with Orbea before the bike is out of any remaining goodwill window.
    668K
