Ohlins RXF 36 setup
MartynG
53
43
Leeds
Following the use Ohlins user guide and trying to set up the fork, I notice the instructions mention a blue dial, and the black dial.
When trying to adjust my forks rebound, I notice that I don't have a black at all (as pictured here)
Very Confused?
OHLINS RFX 36 FORK
Mountain Bike Suspension | RXF 36 Fork Front Fork | Öhlins USA
It seems I am missing the rebound adjustments?
Anyone else have the adjustments or are you missing them too ?
MartynG
53
43
Leeds
I'll check them out, I've also noticed my motor appears to cause drag, not disengage when I'm on a flat and stop pedalling below 15mph it's like engine braking, is there a list of known issues and fixes anywhere?
I think his posts were about the shock not the fork.
Do your forks look like the one in the manual, do you have a black circular dial under your blue one on the front left fork for adjustments
Manual states it's there and describes how to set up the fork but I don't have the dial mentioned in the instructions.
Rob Rides EMTB
Administrator
Staff member
6,146
13,219
Surrey, UK
I think that manual is for the fork on the S-Works, it’s a slightly different (higher) spec than on our bikes.
MartynG
53
43
Leeds
So you don't have the manual adjustment dial under the blue one either then I guess.
How are we to adjust them if we don't have adjustment dials that are mentioned in the instruction manual ???
Mountie
421
254
Canada
No I don’t have it on my ohlins either all good. Same manual covers several fork models.
MartynG
53
43
Leeds
Ok so while this fork is a Ohlins RXF 36 it's actually a cut down version (with out the tuning capabilities) So it loses low or high speed rebound adjustments. Strange they didn't Change the product number or model number considering the loss of features and capabilities.
Mountie
421
254
Canada
Just low speed tuning, it works well and gives good feedback I’m pretty happy with it so far.
MartynG
53
43
Leeds
I am finding that the blue dial must be fully rotated to the right otherwise the front feels really loose, how where do did you find was the sweet spot for your riding style?
Also am I right in saying the ohlins / expert models don't have QR due to their size, is that the official reason?
Mountie
421
254
Canada
Around the seven off of maximum, try a couple of clicks of rebound that should calm the front end down a little. What psi are you running front and rear?
MartynG
53
43
Leeds
I'll try dropping a few clicks and see, it felt awful when fully open just felt like the steering was disconnected from the bars at high speed on tight trails.
PSI in the shocks or tyres :) I'm tuning around 24psi in the front and 26psi in the rear after testing. I feel this gives me good road/trail feel overall. I tried 15psi but again it felt poor due to the increased weight of the bike vs my lighter bike which runs around that pressure.
What about you?
James_MTB
266
216
PSI in the fork?
I was told to fill the bottom (ramp chamber) first and then the top (main chamber)
On big hits\bottom outs, I'm finding air leaking from the main chamber into the ramp up.
Also, i'm getting fork dive on really really steep trails.
I'm approx 93kg (with all biking kit); Ramp up is 240 psi and Mail 140psi
MartynG
53
43
Leeds
PSI in the fork?
I gave you tyre pressures :)
Front Shocks were filled bottom first, and then top chamber filled to what was detailed on the fork for my weight (around 80kg with backpack) around 170psi I think.
Ramp around 190 I think And damper fully turned to the right, but I do like a stiff ride as it gives me more confidence in the front end which is feel is lacking when the front is less dampened.
Mountie
421
254
Canada
What about you?
Hi
The disconnected feel may be the carbon wheels less centrifugal force. Also try a lower pressure that’s sounds a tad high I’m 100 kgs and run 22 rear 19 front and an running tubeless.
518K
