deertrackdoctor
Bike / Product Year: 2025
Manufacturer: Cube
Model: One77 AT
Size Large
Asking Price: 4250
Location Scottish borders TD8
Description Purchased from wheelbase Lake District 09/25
6 months use
18 months Bosch warranty
Message me for a link to high resolution photos
Spec
COLOUR
Blue
SIZE
Large
WEIGHT
24,1 kg
FRAME
C:62® Monocoque Advanced Twin Mold Technology, Aluminium 6061 T6 Rear Triangle, Efficient Trail Control, FSP 4-Link, Agile Trail Geometry, Boost 148, UDH™, Full Integrated Battery, Advanced Internal Cable Routing
SHOCK
Fox Float X2 Factory, 230x65mm, High/Low Speed Rebound & Compression w/ 2-Position Lever, Kashima Coated
HEADSET
ACROS AZF-675, ICR (Integrated Cable Routing), Top Zero-Stack 1 1/2" (ZS 56mm), Bottom Zero-Stack 1 1/2" (ZS 56mm), Fiber Inserts for Angle Adjustment, X-Connect Interface
HANDLEBAR
TAG 50mm riser
GRIPS
ODI ergon
REAR DERAILLEUR
Shimano XT RDM8130 linkglide
SHIFTERS
BRAKE SYSTEM
Sram DB8 Mineral Hydr. Disc Brake (223/203 x 2.3mm)
CRANKSET
Miranda 155mm cranks 36T chain ring
CASSETTE
Shimano XT linkglide LG700
CHAIN
WHEELSET
Newmen Beskar 30 base/strong, 28/32 Spokes, 15x110mm/12x148mm, Tubeless Ready
REAR
TYRE
Maxxis Minion DHF 2.6 wide
SADDLE
ACID Venec EMTB Trail 140
SEAT POST
One up Components r 220mm Dropper with wolftooth remote
BATTERY
Bosch PowerTube 800
DRIVE UNIT
Bosch Performance Line CX 85Nm (BDU38) ab Juli 2025 bis zu 100 Nm/ from July 2025 up to 100Nm
DISPLAY
Bosch Purion 400
FRONT TYRE
SHOCK HARDWARE
Front: 30x8mm, Rear: DU-Bushing 12,7mm
CHAIN GUIDE
Reverse Flip-Guide E-Chain Guide, Direct Mount, I-Plate
STEM
CUBE Performance Stem E-MTB 35, FPI-Link
REMOTE
Bosch System Control, incl. Mini Remote
SUSPENSION FORK
Fox 38 Float Factory GRIPX2, Tapered, 15x110mm, E-Bike Optimized, 170mm, Kashima Coated
