Noob buying first bike - Orbea?
oyzmo
Hi! New to emtb - I'm going to buy my first bike and have been eying Orbea Rise. Are Orbea a solid, durable brand? Looking for an agile, fun and light bike - I'm 177cm and 78kg, live in Europe.
What do you recommend?
Thinking one of these I found on sale:
  • FRAME Orbea Rise Hydro 140mm travel 29" Boost 12x148
  • SHOCK Fox Float DPS Performance 3-Position Evol custom tune 210x55mm
  • FORK Marzocchi Bomber Z2 140 QR15x110
  • HEADSET Acros Alloy 1-1/8 - 1-1/2" Integrated
  • BATTERY Orbea Internal 540Wh (Optional 250 Wh Range Extender)
  • MOTOR Shimano EP600-RS
  • CHARGER Orbea 2.Generation eBike Smart charger 42V/2-4A
  • REMOTE EN600-L
  • CHAINRING e*thirteen e*spec Direct Mount 32T Boost
  • CRANK Shimano Steps EM600
  • SHIFTERS Shimano Deore M6100
  • CASSETTE Shimano CS-M6100 10-51t 12-Speed
  • REAR DERAILLEUR Shimano Deore M6100 SGS Shadow Plus
  • CHAIN Shimano M6100
  • CHAINGUIDE Orbea Rise chainguide
  • HANDLEBAR OC Mountain Control MC31, Rise20, Width 800
  • STEM OC Mountain Control MC20, 0º
  • BRAKES Shimano MT410 Hydraulic Disc
  • ROTORS 180mm Front /180mm Rear
  • WHEELS Alloy, Tubeless, 29", 29c, 32H
  • TYRES Maxxis Dissector 2.40" 60 TPI 3CMaxxTerra Exo TLR
  • TYRES Maxxis Rekon 2.40" 120 TPI 3CMaxxTerra Exo+ TLR
  • SEATPOST OC Mountain Control MC20, 31.6mm, Dropper
  • SEATPOST LEVER Shimano SL-MT500
  • SADDLE Selle Italia Model X FecAlloy Rail 145x248mm
or
Frameset
  • Frame: Orbea Rise SL Hydro 2025, 140 mm travel, 29”, Concentric Boost 12x148
  • Rear shock: Fox Float Performance 2-Pos Evol LV custom tune, 210x50 mm
  • Fork: Fox 34 Float AWL Sport 140, QR15x110
  • Headset: Aluminium 1-1/2”, Black Oxidized Bearing
E-bike System
  • Battery: Orbea Internal 540 Wh (optional 252 Wh Range Extender)
  • Motor: Shimano EP600 RS Gen2 MC
  • Charger: Orbea 2nd gen eBike Smart Charger 42V / 2–4A
  • Remote: EN600-L
Drivetrain
  • Chainring: e*thirteen Helix Core e-spec 32T Direct Mount, 55 mm chainline
  • Crankset: Shimano Steps EM600
  • Shifters: Shimano Deore M6100
  • Cassette: Shimano CS-M6100 12-speed, 10–51T
  • Rear derailleur: Shimano Deore M6100 SGS Shadow Plus
  • Chain: Shimano M6100
  • Chainguide: Orbea eBike chainguide
Cockpit
  • Handlebar: OC Mountain Control MC31, 20 mm rise, 800 mm width
  • Stem: OC Mountain Control MC20, 0º
  • Computer mount: OC CM-05 (Garmin/Sigma)
Brakes
  • Brakes: Shimano MT201 hydraulic disc brakes
Wheels & Tires
  • Wheelset: Alloy, tubeless, 29”, 29c, 32H
  • Tires: Schwalbe Wicked Will Evo TLE 29x2.40, Super Race, Speed Grip, Addix
Components
  • Seatpost: OC Mountain Control MC22, 31.6 mm dropper
  • Dropper lever: Shimano SL-MT500
  • Saddle: Fizik Terra Ridon X5, 145 mm
  • Grips: OC Lock-On
Hi! New to emtb - I'm going to buy my first bike and have been eying Orbea Rise. Are Orbea a solid, durable brand? Looking for an agile, fun and light bike - I'm 177cm and 78kg, live in Europe. What do you recommend? Thinking one of these I found on sale: FRAME Orbea Rise Hydro 140mm travel 29" Boos...
Welcome, @oyzmo. First eMTB - good instinct going for the Rise platform. Orbea are a Basque co-operative with a solid reputation for build quality. Not flashy, not problematic. They've been making bikes since 1930 and eMTBs since the beginning of the segment. Durable? Yes. Removable battery? No - it's integrated, which is worth knowing upfront.
Now, the two bikes you're looking at are actually quite different animals, so let's be clear about what each is.
Option 1 - Rise Hydro (H30) is the alloy entry-level model with a Marzocchi Bomber Z2 fork, Shimano MT410 brakes (2-piston), and Maxxis rubber. Motor is the EP600 RS Gen2.
Option 2 - Rise SL Hydro is also aluminium but one level up - Fox 34 fork, slightly better brakes (still 2-piston MT201), Schwalbe Wicked Will tyres. Same EP600 RS Gen2 motor.
Both are in the "super light" trail category - 140mm of travel both front and rear.
Geometry is modern but agility-oriented: head angle around 65.5° and a steep seat tube angle around 78.3°. On a medium, reach is 465mm
- which at 177cm is exactly where you'd land and is a sensible fit. The EP600 RS Gen2 is a detuned, efficiency-tuned version of the full EP8/EP801 family.
Compared to the previous RS generation, the Gen 2 delivers power at lower cadences and unlocks the full 85Nm available. It's not a beast - it's a motor that rewards pedalling rather than replacing it. For agile trail riding, that's actually the point.
