Levo SL Gen 1 New Turbo Levo SL rear mudguard from Central Coast Bikes
Will Hesch
68
115
93422
Central Coast Bikes, the folks who brought you the original Turbo Guard for the 2019-2021 Turbo Levos is proud and excited to announce the new Turbo Levo SL Turbo Guard rear mudguard.
The SL Turbo Guard installs in minutes using the 2 small bolts that hold the lower chainstay rubber thingy in place. That's it, unbolt the thingy, place the Turbo Guard behind it, put the screws/bolts through the thingy and Guard, center the Guard and tighten the bolts/screws and you're done!
Available at www.centralcoastbikes.com for $14.99
Shinn
375
276
Decorah, IA USA
Looks like it may keep some of the crud out of the little cubby hole behind the motor. Kinda ugly in my opinion though.
thanks for sharing.
Will Hesch
68
115
93422
Redesigned. The Levo guard took a redesign to fully develop and the SL guard did too.
We’ve shortened it by 2 inches and creased it to center it between the upper linkages And added a peel & stick adhesive to the base which holds it in place while installing the two bolts.
522K
