Hey Wolfgang, welcome. Hope the Kenevo is going well?Hi from Austria. Received my Kenevo Expert on Friday, and will share my first experiences in the kenevo forum.Wolfgang
On @Kiwi in Wales recommendation I’ve just bought the 2.6 Magic Mary you mention above. I’ll let you know how I get on (Levo).Hi Rob
thank you for asking. Hm, its an amazing bike but - coming from a haibike nduro with minion dhf 2.5 dhf dd/dhr2 2.4 dh casing and having the Mm sg 2.4 on my spec enduro I dont like:
1. the 2.6 butcher tyres (I changed from 2.8 tp 2.6 because the 2.8 on the test bikes felt a bit spongy and inprecise) which feel bad concerning grip and traction on steep trails compared to the tyres above. This is really a problem which we have to solve. Such a great bike but without good grip ...
2. the brake starts quieking after appx 200 m altitude difference (but Im a very cautious driver) - however the Magura Mt5 on the haibike nduro made 1000 altitude meter without any noise. Will switch to the mt5 or mt 7 again.
What I am not sure about is if I should stay at 2.6 oder change to 2.8
Main request is if I should take the MM ultrasoft dh case or the Minion 2.6.
To avoid tyre breakdown, snakebites etc when riding in the alps and bikeparks is crucial for me.
if you have advices I‘m thankful ?
regard
wolfgang
ok thanks. We re going to Reschen/Nauders in the alps by end of August and Id have switched it from my shop until then. Do you think you will have first experience by next weekend? Steep trails on dry earth - also with loose small stones - makes most problems ...
thanks a lot in advance
75 kg full quipped, 78 kg with full protector
95% without full protectors in our wood trails here
steep trails have have bit of kind of gravel.
i read your long great post carefully and will change to mm dh ultrasoft 2.6 as recommended.
1.4 kg, hope it wont reduce range of bike /battery not too much.
My bikestore (big and established one) here promoted Schwalbe in the past but avoid them now. dont know why -i think they said due to difficult tyre change compared to other brands.
thanks a lot for your advice
@kiwi: do you ride the mm 2.6 dh ultrasoft on the rear as well or soft? i ordered ultrasoft for rear as well as front. is this ok ?Hi @profgruen, Have a look at the link below to a recent post I did on both the 2.8 and 2.6 MM tyres.
I think the MM 2.6 DH casing Ultrasoft will be a very good choice in the Alps for you as they have thick, strong sidewalls. I would not recommend the MM 2.8 as their sidewalls are almost as thin as the Butchers. How much do you weigh? As this will determine how much air pressure you will need in your tyres. I weigh betweeen 73 and 75kg fully kitted up. In an Alpine environment I would run the tyres with 6 to 10 more psi than I normally would on my local trails.
Regarding grip on loose, small stones. How small? and how loose? If you are describing a sea of ‘pea’ size stones then I am not sure any tyre will cope with this unless there is a good base below the stones where the knobs of the tyre can grip on to and you are comfortable with your drifting skills.
Hope this help you in your decision.
Kenevo and Levo stock Butcher tyres - grip questions ??? - EMTB Forums
I have 17 to 18 psi in both front and rear and have never had a snake bite. This is on my local trails in Walesperfect, thanks for your quick answer! this is rweally helpful!
one little - perhaps a bit stupid - question: did you ever check how low you can go with mm 2.6 dh ultrasoft front resp. rear before snakebites, cuts etc when assuming 75 kg riderweight and with the kenevo?
thanks
I recieved 2 new ones in the post todaysuper. thanks a lot. now i've got everything i need to know on the mms!
looking forward to a geeat ride with them.
regards
wolfgang
