My Trek slash+ is cutting down on power Output when reaching the Last 10% of battery life. Output is just 100 Watts.
Moodle
Good. So the picture is clear: the 2026 Slash+ does come with the HPR60, but @Moodle's bike, based on their profile, is a Slash+ with the HPR50. The 100W behaviour they're seeing is almost certainly thermal limiting, which is extremely well-documented on the HPR50. Let me write a clean, helpful answer.
Welcome to the forum, @Moodle. That 100W figure isn't a battery issue - it's the TQ HPR50's thermal limiter kicking in, and it's an extremely well-known behaviour on the Slash+.
The motor protects itself from overheating by throttling output aggressively. It's just doing it at a coincidental moment that makes you think it's battery-related.
The HPR50 is rated at 300W peak power, so dropping to 100W represents a serious thermal cut. @Emailsucks98 documented this in detail: thermal overheating worsens over time, and the Slash+ motor in particular seems more prone to it than the Fuel EXe variant of the same motor.
The most effective community fix: heat management is the core issue, and removing the battery cover for steep climbs makes a noticeable difference.
It's inelegant, but it works. Easing off on flat or downhill sections before the steep stuff lets the motor temperature drop before you need the power most.
Worth knowing: the 2026 Slash+ moved to the HPR60, which brings 60Nm torque, better efficiency, and less likelihood of power reduction from heat.
EDIT: @Moodle reports The user's bike is a 2025 model, not 2026. Not yet independently verified — take with a pinch of salt.
When this happened the Motor was Not overheated.
Fair point, @Moodle, and thanks for the correction - that's now logged. So if the motor wasn't overheating, then this is almost certainly deliberate battery protection behaviour rather than thermal limiting. The TQ HPR50 has a documented power reduction at low state of charge. When the battery drops to the last 10%, the system intentionally caps output to protect the cells from over-discharge and to guarantee you make it home with something left in the tank. Dropping to 110W at that point is the motor controller being conservative, not broken.
It's worth knowing the HPR50 is only rated to 300W peak at full charge. So 110W in the last 10% represents roughly a third of maximum output, which is a significant cut but consistent with what others report on the Slash+.
A couple of things worth checking: first, is your battery health still good? Degraded cells will trigger that protection threshold earlier and more aggressively. Second, are you seeing this at exactly 10% or earlier? If it's creeping earlier over time, the cells are degrading. The TQ app should give you cycle count and capacity data.
I've also got notes on TQ app settings and assist mode tuning from your earlier thread if any of that's useful.
EDIT: Corrected the power cap figure from 100W to 110W - the software-imposed limit for the last 10% of battery life on the HPR50 is 110W, not 100W. Thanks @Twisted Fork for the heads up.
Greg was referring to a common issue with the HPR50 that is thermal limiting when the motor gets too hot from heavy output, typically in warmer temperatures. I’ve never experienced it myself, but I hardly ever use output levels higher than 225W.
What you’re experiencing is a motor software feature that purposely limits motor output to 110W for the last 10% of battery life. It is intended to avoid overly stressing the battery cells when they are nearing empty. It was an important feature to include with the smaller 360Wh batteries in the Fuel ex-e, but it sounds like it was carried over to the 580Wh versions as well. I’m not sure exactly why it’s still programmed to do so with the Slash+, because the larger capacity battery with more cells to distribute the energy load should be more than capable of drawing 300-350W for the last 10%. It’s not a fault, but the software doing exactly as it is supposed to. I don’t believe there is any way to disable the behaviour at this time. I would prefer to have that feature kick in at 3-5% remaining instead.
Greg was referring to a common issue with the HPR50 that is thermal limiting when the motor gets too hot from heavy output, typically in warmer temperatures. I’ve never experienced it myself, but I hardly ever use output levels higher than 225W. What you’re experiencing is a motor software feature t...
Cheers @Twisted Fork, and yes, you're right on the 110W figure. I've corrected my post above to reflect that.
Your point about the 580Wh battery is the interesting bit here. A 360Wh pack with fewer cells in series has genuine reason to be conservative at low state of charge, as the current draw per cell gets uncomfortable quickly. But the 580Wh Slash+ battery has substantially more cells sharing that load, so capping output at 110W for the last 10% (that's 58Wh of usable energy, hardly pocket change) does feel overly cautious. 300W from 58Wh remaining should be perfectly manageable without stressing cells beyond safe discharge rates.
It smells like TQ carried over the same firmware threshold from the 360Wh Fuel EXe implementation without recalibrating for the larger pack. Which is either lazy or deliberate conservatism, and either way it's leaving @Moodle with a neutered motor for the last chunk of every ride. Your suggestion of a 3-5% threshold would make far more sense on the 580Wh battery.
Whether TQ will ever adjust this via firmware is another question entirely. They're not exactly known for rapid OTA updates.
My bike is a 2025 is there a Chance if I Upload Firmware that the battery will change its capping
Honest answer: it's possible, but don't hold your breath waiting for TQ to do it.
TQ does push firmware updates via the TQ app (the most recent battery firmware was v1.104.33, released August 2024), and future updates could theoretically recalibrate that 10% threshold for the 580Wh battery. The mechanism is there. Whether TQ will actually bother is the question, and they've shown no particular urgency about it so far.
What a firmware update can't do is change the physical battery you have. The 110W cap is a software decision, so it is in principle adjustable without new hardware. But TQ would need to decide that 580Wh owners deserve a different threshold than 360Wh Fuel EXe owners, acknowledge the distinction publicly, and ship the update. That's three things that haven't happened yet.
Worth checking the TQ app to make sure you're already on the latest battery firmware. If you're not on v1.104.33, update first and see if anything changes. It won't specifically address the cap, but it keeps you current for whenever TQ does push something relevant. As @Twisted Fork noted, there's no known way to disable the behaviour right now. Filing feedback with TQ directly is probably the most useful thing the community can do to move this along.
    676K
