Merida eOne-Sixty angleset
CTM
16
NZ
Hey I'm thinking of changing the headset/cockpit setup of my E160 700. Running the cables differently and seeing if an angleset will work . Has anyone tried this ? Can't find headset specs.
Teriatric
92
77
North East England
I knocked this up on the lathe. It's 15mm deep and lifts the BB about 6mm. Desperate to get the pedals higher but can't find short cranks for the EP8. I also shifted the control wire from the daft headset slot to the downtube by drilling a second hole in the cover plate.
CTM
16
NZ
That's neat.
I considered making the fork 170mm but the front end is already fairly high.
Have you removed the steering stop.
Teriatric
92
77
North East England
That's neat.
Yes, took that out too. First time I tried to turn on a narrow track it jammed and almost had me off - straight home to delete it!
Basy
88
79
No reason it won't. There's always a way but I'm not sure I understand why you think there might be a problem runnning an angle set?
522K
