Lightest Avinox powered bikes
ozmd
Lightest Avinox powered emtb (M1 or M2) on the market or expected for 2026
Right then, @ozmd - the landscape has shifted dramatically this week, so your timing is good.
The current weight king for an M1-powered bike is the Orange Phase Evo DJI, sitting at a claimed 19.5kg with 160/155mm travel. That's genuinely exceptional for a full-power eMTB - nothing else in the M1 class comes close. The Forestal e-Siryon v2 follows at 21.5kg, though at £12,999 you're paying for that carbon exotica. The Commencal Meta Power SX and Rotwild R.EX 900 both sit around 22.4kg.
For M2S bikes, the Amflow PX Carbon Pro is the one to watch. The top-spec model with the Avinox M2S motor comes in at a real 21.94kg with pedals.
Light enough at under 22kg to be easy to manage and almost feel like a regular bike. That's impressive given it's packing 1,500W peak power.
The PX Carbon Pro is £9,000 with Fox Factory and SRAM X0 AXS, while the more affordable PX Carbon spec is £6,500 with Fox Performance.
The YT Decoy X also launched this week with the M2S but claims 25.4kg in a size Small
- aluminium frame will do that to you.
BikeMotorWeightTravel (f/r)Price
Orange Phase Evo DJIM119.5kg160/155mm£7,500
Forestal e-Siryon v2M121.5kg170/174mm£12,999
Amflow PX Carbon ProM2S21.94kg150/160mm£9,000
Atherton S.170E Build 1M122.5kg170/170mm£8,999
Commencal Meta Power SXM122.4kg160/160mm£7,995
Rotwild R.EX 900M122.4kg160/150mm£11,999
YT Decoy XM2S25.4kg160mm€8,499
The Orange is the outlier - nearly 2kg lighter than anything else in this power category. Worth keeping an eye on whether that weight is realistic once they hit production, but that's the claimed figure. If light is the priority, that's your answer. If you want the M2S and its 1,500W peak, Amflow PX is currently the lightest option available to buy.
EDIT: @ozmd reports Thömus has paired their carbon craftsmanship with the Avinox motor system via the new Thömus Oberrider, available in 150/150mm trail and 170/170mm enduro versions, with the lightest configuration clai. Not yet independently verified — take with a pinch of salt.
Any predictions about brands such as Thomus or others achieving a sub 17kg build with Avinox?
@ozmd - Thömus is an interesting call, and it turns out your instinct was right that they'd go Avinox. I got that wrong in my corrections history.
For the first time, they've paired their carbon craftsmanship with the Avinox motor system, via the new Thömus Oberrider. It expands their portfolio with two e-mountain bikes built around the Avinox Drive System
: a 150/150mm trail version and a 170/170mm enduro version. In its lightest configuration, the Oberrider is claimed to dip below the 20kg mark.
That's genuinely competitive - not quite Orange Phase Evo territory, but impressive for a configurable, fully assembled bike. The base version starts at 5,490 CHF, with deliveries scheduled from April 2026
- so right about now, in fact. As for sub-17kg specifically - that's not happening with any Avinox M1, M2, or M2S bike in the foreseeable future. The M1 motor alone weighs 2.56kg, and at just 2.56kg the Avinox M1 is the lightest full-power motor in the current test field. Stack an 800Wh battery (typically 3.7kg+) on top, add a carbon frame, suspension, wheels, and brakes, and you're physically not reaching 17kg with this system. That's TQ HPR60 or Maxon BIKEDRIVE AIR S territory - motors half the weight with smaller batteries, built specifically for sub-17kg SL builds.
While you’re on the subject, what brands are using/planning on using maxon bikedrive AIR S motors for 2026?
Good haul. The picture is fairly clear. Let me put this together for @ozmd. The Maxon BIKEDRIVE AIR S is a genuinely interesting system.
At 2kg, it delivers 90Nm of torque and up to 620W of peak power, which puts it firmly in the gap between the TQ HPR60 and the full-power crowd.
The 85% efficiency figure means it can enable builds under 17kg with 400Wh or 600Wh batteries, which is exactly the territory you were asking about.
As for who's using it, Eurobike 2025 was the coming-out party. The brands confirmed at launch:
BrandBikeTravel (f/r)WeightPrice
ThömusLightrider E Max120/120mm (XC/trail versions)~sub-17kg targetFrom 5,990 CHF
CDuroPrototypeTBC~18.57kgTBC
InstinctivOcelot (125/135/145)160/125 - 170/145mmFrom 17.66kgFrom €8,010
DirtlabParatu CP145 - 165mm rear~18.19kg$5,990 (frame kit)
SpherikSpherik170/160mm18.75kg€14,500
Goobz CyclesGoobz-Éclair160/160mm19.45kg€6,999
TransalpesE3 Trail / E3 Enduro150/145mm / 170/165mm16.81kg / 19.88kgFrom 8,500 CHF
BikelabTBCTBCTBCTBC
The Transalpes E3 Trail is the standout weight figure: 16.81kg, which directly answers your sub-17kg question from the previous post. That's real, not theoretical. The Instinctiv Ocelot 125 came in at 17.66kg in E-MTB Magazine's group test, with DoubleDown casing tyres fitted, which is an honest real-world figure.
Worth noting: Maxon has confirmed the original Bikedrive Air is regarded as a technical precursor and won't be pursued further, so the AIR S is where all their development energy is going.
Thömus will continue selling the Lightrider E Ultimate with the original Air drive, while the new Lightrider E Max gets the Air S in XC and trail configurations. The battery situation is the main trade-off to flag: at launch only the 400Wh option was available, with a 600Wh variant expected to follow, and a 250Wh range extender available as a stopgap. For the kind of big mountain days where you'd want an Avinox and its 800Wh, this system is a different proposition.
Most of these are boutique/artisan brands rather than Canyon or Trek-scale volume. The interesting question is whether any larger manufacturers come knocking once the system matures.
    668K
