Levociraptor
ReikoW
the max speed selector is great, but I'm wondering if it is possible to modify this cable with an external button. so i can change the setting without removing the tcu...
just ordered one to check it out...
TrailwattsUK
Trader
Aug 27, 2018
815
684
Kent
Any modification to the unit will void its warranty and you won’t be able to modify the unit.
Sorry but it’s designed to be a stealth module.
TrailwattsUK
Trader
Aug 27, 2018
815
684
Kent
As far as I understand it, however, the speed and distance measurement is falsified.
When used with BLEvo, adjusting the speed multiplier and setting correct wheel size will provide the bike with derestriction and less miles covered.
McInner1
227
173
Austria
When used with BLEvo, adjusting the speed multiplier and setting correct wheel size will provide the bike with derestriction but still have accurate speed/ distance figures.
That's clear, but the total mileage stored in the Levo-TCU will be falsified, won't it?
TrailwattsUK
Trader
Aug 27, 2018
815
684
Kent
The tcu will be updated by the levociraptor giving less mileage. This is why the speed multiplier and wheel circumference is set at the end of installation.
Galion
99
119
Brazil
Please check updated firmware list on website.
Not compatible ☹️ 2020 firmare is: Battery 2.4.4 and Motor 6.1.1, MC 22B, hope this guys come up with a solution soon, thank you.
TrailwattsUK
Trader
Aug 27, 2018
815
684
Kent
So anybody using with sucesss ? Does fitting involve any cutting or the like or is it simple plug in , and plug out ?
Levo 2019 Carbon comp
Instructions are on this thread for information.
  • Levociraptor - Install .pdf
Apples
134
127
Wiltshire
Thanks for some reason I’ve never been able to open that on my iPhone , but as I was at work I opened it on my PC and printed it , thanks for the info .
I’m a year in so another year left on Warranty, so might wait till that is gone before I use it .
The limit does not impact me too much but I would prefer to be unlimited
TrailwattsUK
Trader
Aug 27, 2018
815
684
Kent
I think you’ll be on a new bike by then??
TrailwattsUK
Trader
Aug 27, 2018
815
684
Kent
Got mine in and operational. I just shoved it in the tubing without velco...its fine. Does what it says and no issues! Now lets see if my legs can actually pass 20mph uphill.
Advise you stick it as vibration could damage the unit over time.
jmulvaney
26
33
Gold Coast, QLD, Australia
Just fitted mine today. Took minutes (need a T10 screwdriver - looks like a small allen key style hexhead). And it works! No cutting. Just plug and play. Instructions were clear and easy to follow. Using with Blevo app.
522K
