• Warning!!
    UK Pedelec Law
    Worldwide Laws
Levociraptor and Levo Gen4
Pre-order is now open also for USA riders
Interested but have two questions before I order…
1. Does the product completely remove all speed limits? Occasionally I reach the 28 MPH Class 3 speed limit and would be buying to remove that.
2. Does the product remove the Class 3 narc screen pop up? Not critical but I’d find value in the narc screen going away.
Yes, the 28mph limit is removed. For the pop up I don't know sorry. But you can change the class to lower class without pop up and use only Levociraptor to remove the speed limit
Virtual suggestion box submission: I wish there was a 'Lite' version that locked out live BLevo app integration in exchange for a lower hardware cost. While I do like the ability to monitor motor and battery temperature; I won't be running the BLevo app while I ride. I just want to eliminate the speed limiter.
The most expensive part of the product is not the connection to BLEvo, but the speed unlimiter. So a product without BLEvo will not cost less
Interested to see any feedback before i order... anybody got one in the post?
Yes, installed friday and ride for 120 km on the weekend. Close to perfection on standard modes (Eco/Trail/Turbo/Auto)
Still some small issue with Microtune, but i'm sure that Paolo will solve and update the device constantly
I will test the Microtune today, evenif during the test done in the past, no issue was found.
Honestly I don't see any correlation between Levociraptor and Microtune.
I will update you.
I will update you.
Could you customize the individual modes between with a Paolo update?
I mean that each mode that the bike carries can be individually customized
You can customized the ECO/TRAIL/TURBO via Specialized App. Microtune can be adjusted during riding with the remote control. I don't think this is the answer of your question...
I will update you.
I did the test with Microtune and Levociraptor and I didn't find the issue notified by the customer.
I'm in contact with him to understand better what happened
The problem of the customer could be related to the contact of the battery, not to the Levociraptor Gen4 and the Microtune mode.
I suggest to clean sometime the contact of the battery to avoid any shutdown of the bike during riding.
It seems you are right. Yesterday i did another small test and all went perfectly
I will do more test during the weekend but i’m very satisfied
Thanks once more
Might also be worth checking if they have the old non spring loaded battery nest.
Yes, i got the old one. But the new parts is still unavailable.
- S256800029 new - S246800004 old
- S255300007 new
The old one (004) was substitued by the new with spring (029) and it needs also 007 for me.
Somebody can confirm ? I try to find it on the web but no good result
- S255300007 new
Best off going to a local Specialized dealer. The new nest has been available for a long time now. They should be able to order one for you .
the crobikes link at the top triggers this message...
I checked and it is working correctly..
Are you using this link?
    668K
