Is the Teewing Flux One Able to Run Sram AXS T-Type TRANSMISSION?
Singletrackmind
San Diego, CA
The new Teewing Flux One has me intrigued and looking at options to the Crestline RS181.2 since they are not so readily available.
Could you compare the 2 bikes? Do you have any information on the Teewing's capability to run SRAM AXS T-TYPE transmission?
Are Teewing available for sale in the United States?
The new Teewing Flux One has me intrigued and looking at options to the Crestline RS181.2 since they are not so readily available. Could you compare the 2 bikes? Do you have any information on the Teewing's capability to run SRAM AXS T-TYPE transmission? Are Teewing available for sale in the United ...
@Singletrackmind, the Teewing Flux One has been generating quite a bit of buzz on the forum, and I can see why it's caught your eye given the Crestline availability situation.
Let me start with what I know, then I'll go hunting for what I don't. Additionally, here's what I've pulled together. You've got three solid questions, so let me take them in order.
1. SRAM AXS T-Type Compatibility with the Teewing Flux One The short answer is yes, with a caveat.
The Flux One A is fully UDH compatible and comes equipped with a SRAM Eagle 90 mechanical drivetrain.
Since UDH compatibility is the fundamental requirement for SRAM T-Type Transmission, Eagle Transmission requires that the frame is Universal Derailleur Hanger (UDH) compatible due to its unique hangerless design.
So the frame itself is ready to accept an AXS T-Type derailleur. The piece you'll need is the SRAM AXS power cable to connect the derailleur to the Avinox motor for features like Coastshift and Chain Protection. Community knowledge confirms the correct part number is 11.3018.028.003, the 780mm SRAM AXS E Transmission cable, and that both the 780mm and 955mm versions work with Avinox bikes. Given that the stock Eagle 90 drivetrain is already T-Type, swapping to an AXS T-Type derailleur (GX, X0, or XX) is a straightforward upgrade within the same ecosystem.
If it's a T-Type component, it's compatible with all other Eagle Transmission T-Type parts, whether AXS or Mechanical.
You're already running SRAM AXS Transmission on your other builds, so this would be familiar territory. The forum also notes that the Eagle 90 on the Flux can be converted to GX Electronic for Coastshift and Chain Protection features with Avinox, so you're looking at a very clean upgrade path.
2. Teewing Flux One vs Crestline RS181.2 Both are DJI Avinox M1 powered, 800Wh battery, full carbon enduro platforms. Here's where they diverge:
The Flux is a high-pivot design with the chain running up and over the idler pulley, then threading directly through the chainstay, giving you that rearward axle path for better bump absorption.
The suspension delivers 178mm of rear travel in mullet mode, with a flip chip at the Horst link letting riders choose between mullet or full-29er, which drops travel to 170mm.
Another flip chip at the lower shock mount provides high and low geometry settings. That's a lot of adjustability.
The Crestline RS181.2, by contrast, is a more conventional four-bar at 180/181mm travel. Our verified geometry for the RS181 in size RH-3 (which would be equivalent to your Large) shows 480mm reach, 650mm stack, 63.5° head angle, 78.5° seat angle, 447mm chainstays, and 1280mm wheelbase.
For the Flux in Large, we believe a Large bike will have a reach of around 480mm, a head tube angle of just under 64 degrees, a seat tube angle of 78 degrees and a 445mm seat tube length.
The geometry data on Geometry Geeks shows 3 sizes: 634|455, 642|480, 655|505, stack|reach which aligns with that. So the two bikes are remarkably similar in reach at size Large, though the Flux appears to run slightly shorter chainstays.
SpecTeewing Flux One (L)Crestline RS181 (RH-3)
MotorDJI Avinox M1DJI Avinox M1
Battery800Wh800Wh
Reach~480mm480mm
Stack~642mm650mm
Head Angle~63.5°63.5°
Seat Angle~78°78.5°
Rear Travel170mm (29) / 178mm (MX)181mm
ForkFox 38 Performance 180mmFox 38 (spec dependent)
Suspension TypeHigh-pivot w/ idlerConventional 4-bar
Mullet OptionYes (flip chip)No (29 only)
Geo Adjust2 flip chips (wheel size + geo)Limited
Stock DrivetrainSRAM Eagle 90 T-TypeSRAM AXS T-Type (incl. power cord)
Expected Price~€6,899£6,999
The key differentiator is the high-pivot layout on the Flux. For San Diego's rocky, chunky terrain that should be a genuine advantage on the descents, though the idler does add a friction point and a bit of extra maintenance. The Crestline RS181.2 is a known quantity with a more conventional suspension design and, notably, comes with the SRAM AXS power cord included so you'd have Coastshift out of the box.
3. US Availability Teewing has partnered with Drip e-Bikes to bring their bikes to the United States.
However, that's currently for the Turbo Force (the trail bike), and all bikes are currently being made-to-order with about a 6-7 week lead time.
Demo rides are only available in the Metro Atlanta area, but they offer a 30-day money back guarantee for those outside of Atlanta.
As for the Flux One specifically, its release is slated for the first half of 2026, and it's not yet listed on the Teewing or Drip e-Bikes websites for purchase. Given the Drip e-Bikes partnership already exists, I'd expect US availability through the same channel once the Flux launches, but I'd contact them directly to get on the pre-order list. Being in San Diego, Atlanta isn't exactly round the corner for a demo ride, but at least the purchase channel exists.
Worth noting: the Crestline RS181.2 comes with the SRAM AXS power cord for Smoothshift compatibility as standard. On the Flux, you'd be starting with the mechanical Eagle 90 and upgrading to AXS yourself, which adds cost but also means you choose exactly which tier of AXS you want. Given your track record of building bikes to your own spec, that might actually suit you better.
Battery800Wh800Wh
Reach~480mm480mm
Stack~642mm650mm
Seat Angle~78°78.5°
Do you know if Teewing offers a frame only option?
@Singletrackmind The frame-only situation with Teewing is a bit of a moving target, unfortunately. The community intel is mixed. @iamandisykes mentioned that Teewing plans to offer framesets for the Flux, and there was talk of it being priced slightly above the Turbo Force frame cost. However, @B Rabbit reported that a Teewing retailer in Australia indicated the frameset option has been discontinued by the manufacturer as of December 2025, with only complete bikes available going forward. So it's possible that whatever frame-only plans existed have been shelved, or it may vary by market.
Given that the Flux isn't even available for purchase yet (first half of 2026 is the current window), I'd say the honest answer is: it's unclear, and likely to depend on how Teewing and their US partner Drip e-Bikes structure the rollout. Worth contacting Drip directly to ask, since they'd be your purchase channel in the States.
If a frame-only build is what you're really after, the Crestline Avinox frameset is the more proven route for US buyers. The next batch is 300 frame kits, available with 600Wh or 800Wh battery, and a choice of Fox X2 air, DHX2 coil, or Vivid coil shock. They do sell out fast though. Given your history of meticulous custom builds, that might actually be the path of least resistance, even if the high-pivot design on the Flux is tempting.
Appreciate the insight. One last Teewing question. Do you have information on dropper post insertion depth? I run a 200mm SRAM AXS B1 dropper on my 2026 Orbea Wild and can only fit a 175mm SRAM AXS B1 on my Crestline S180. Understand there's other mechanical droppers that would afford me the ability to run a 200mm dropper, but Im partial to SRAM AXS Droppers. Love how smooth they are and detest cables.
Appreciate the insight. One last Teewing question. Do you have information on dropper post insertion depth? I run a 200mm SRAM AXS B1 dropper on my 2026 Orbea Wild and can only fit a 175mm SRAM AXS B1 on my Crestline S180. Understand there's other mechanical droppers that would afford me the ability...
@Singletrackmind The Teewing Flux is genuinely interesting territory here, because the community knowledge we have is a bit of a mixed picture for your specific needs.
The forum data shows the Flux Medium frame has a maximum dropper insertion depth of 243mm. For the Large, there's a note that the seat tube is shortened to accommodate 170-180mm droppers, which is concerning given you're running a 200mm on your Wild and want to replicate that experience.
The SRAM AXS B1 200mm dropper has a 311mm insertion depth (that's the number you worked out on your Wild build). If the Large Flux seat tube is genuinely optimised around 170-180mm posts, you're likely looking at the same constraint you hit on the Crestline S180, possibly worse. The SRAM AXS stack height of 64mm versus something like OneUp's 30mm doesn't help matters, as you already know from the S180 experience.
Worth running the SRAM dropper calculator at sram.com with whatever seat tube length Teewing publishes for the Large before getting too far down this rabbit hole. If the insertion depth ceiling is around 280mm or less, the 200mm AXS B1 is off the table regardless of the frame being UDH compatible and otherwise perfect for your build.
The honest answer is that I don't have a confirmed insertion depth figure for the Flux Large specifically, and given the bike isn't shipping yet, that number may not even be publicly available. Teewing's own tech support would be your best source, or watching closely for owner reports once the first bikes land. Given the S180 constraint you've already navigated, it's absolutely the right question to ask before committing.
Teewing are available through DripE bikes and other distributors in the USA. And yes you can run AXS. If you buy a non AXS bike and upgrade and want to make use of the internal battery and Avinox smart shifting, you will also need a SRAM cable that connects the rear mech to the Avinox system.
    668K
