Hardseven 2.5 direct mount chainring
Slymobi
863
2,281
UK, Derbyshire
My current is a 38T direct mount that looks offset in someway that has a fitting with 28 teeth around and I've seen some SRAM and Kmc but both state Bosch where my motor is the Yamaha pw-st. Then I've seen loads of chainrings that have a total different fitting standard etc and then others that need a separate spider altogether, so I'm getting confused for the correct replacement.
Thanks in advance
Jackware
Fat-tyred Freakazoid
1,889
2,050
Lancashire
You're correct it's a Direct Mount chain ring with 28 internal teeth (even though there's two types using that name :rolleyes:).
I don't know if you need to take chainline offset into consideration though :unsure:
Slymobi
863
2,281
UK, Derbyshire
They are both the ones I seen but confused as states they are both Bosch. The haibike 2.5 is a Yamaha motor. Is it just me or is everything such a PITA when it comes to Haibike parts !
The only marking on the existing is the brand Miranda, no part number, sizes or anything. Go to the Miranda site and this chainring doesn't exist lol.
Slymobi
863
2,281
UK, Derbyshire
I have NO idea why the KMC Bosch Gen 4 ring fits but I've had 2 ( 34T and 38T ) since this issue and both still in great condition.
521K
